1 liter metro engine in Kick?
  • 13 Replies
  • 3866 Views
Offline MRDEAN40
  • 20
« on: April 04, 2007, 02:23:43 AM »
Does anyone know if the little 1.0L engine from a Metro will bolt in to a Track/Kick? I know they also used the 1.3 in some Metros.
ZukisandRotarys
Re: 1 liter metro engine in Kick?
« Reply #1 on: April 04, 2007, 03:05:28 AM »
do you really want to put a 50 hp motor in a tracker?
ZukisandRotarys
« Reply #2 on: April 04, 2007, 03:13:30 AM »
Offline MRDEAN40
  • 20
« Reply #3 on: April 04, 2007, 01:34:07 PM »
It's just an idea for getting great mileage and still having the use of 4 wheel drive. More of a experiment. I know it wouldn't be great off road and would have to stay with small tires. More for commuting around town.
Offline BigPig
  • 276
« Reply #4 on: April 04, 2007, 01:52:44 PM »
Just put a Sammi straight axle under a Metro.   ;D
'89 Sidekick w/ 4.5" of lift.
caymin
« Reply #5 on: April 04, 2007, 04:01:03 PM »
I actually pondered the same thing! My idea was to use the engine out of the 1989 chevy sprint turbo. They were a peppy 3cyl turbo that got great milage. Where there's a will there's always a way!
Caymin
Offline kirknd4spd
  • 333
« Reply #6 on: April 04, 2007, 11:12:39 PM »
would a 50hp 1.0L even pull a sidekick up a hill?  ???  i think that would hurt more than help.
« Reply #7 on: April 05, 2007, 08:21:54 AM »
Just because the engine gets good mileage in a small sleek car doesn't mean it will get good mileage in a larger heavier tracker. It is so underpowered for that vehicle it will probably get worse mileage than your 1.6.
Offline Amilla
  • 1076
« Reply #8 on: April 05, 2007, 09:07:52 AM »
Gears solve everything...except if you want to cruze with the rest of traffic.
Amilla
Offline PHX96TRACK
  • 90
« Reply #9 on: April 05, 2007, 10:28:14 PM »
Yeah, without gearing changes I can't imagine that engine would work in a tracker at all. The 1.6 is pretty small. You'd be going uphill in 3rd gear at 30 mph at 5,000 rpms. Just a guess.
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #10 on: April 08, 2007, 11:08:25 PM »
Here in Okinawa they drive 660cc 970cc in a Sammy(Jimny) stock.  Of course they have turbo, too.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #11 on: April 10, 2007, 12:00:41 AM »
you would definatley get worse gas mileage because the engine would have to work that much harder to move the vehicle. it would be hard on the engine too because it was not designed to move that much weight.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline RHodge
  • 523
« Reply #12 on: April 10, 2007, 06:09:29 PM »
just go with a hayabusa 1300 in it  >:D
Ryan
Offline Armour
  • 360
« Reply #13 on: April 10, 2007, 07:20:05 PM »
I think too much weight in a tracker for a 1.0L.
