Body lift
  • 1423 Views
Offline museboy07
  • 641
Body lift
« on: April 10, 2007, 11:22:55 AM »
Hey guys,
Im on my brothers user name since i dont have one...anyway...i want to put a 2in bodylift on my 92 track.  The thing is i can see that the body mount bolts are rusted sorta bad.  Anyone do a bodylift when the bolts were rusted like that?  How long did it take you?  did you have to cut anything?
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: Body lift
« Reply #1 on: April 10, 2007, 11:32:23 AM »
The only ones that gave me troubles were the front ones underneath the headlight area. Once the front bumper is off you can torch a small hole to gain access to the "nut" area to allow heating to get the bolt out or to add penetrating fluid. This area will be covered up again so the hole will not be noticeable.
Jim
