A loose electrical connector...
  • 10 Replies
  • 3598 Views
Offline DoRoN
  • 1990 Kick
    • Doron 4x4
« on: December 22, 2004, 02:38:26 AM »
I found this blue connector hanging loose near the battery, and I can't find any place to connect it.
Does anyone know what it is, and where it should be connected?
The car is a 1990 auto 2 door Vitata, Japanese made.
Tnx
Doron
http://www.omghi2.us/april05/DoRoN_sig4x4.JPG[/IMG]Free your mind, and the rest will follow...
Re: A loose electrical connector...
« Reply #1 on: December 22, 2004, 02:45:09 AM »
Sometimes connectors are left like
that for a diagnostic computer to
hook up to.
Do you have anything that doesn't work ?
Any problems you can't explain ?
Offline DoRoN
  • 1990 Kick
    • Doron 4x4
« Reply #2 on: December 22, 2004, 02:53:29 AM »
Well, I've installed a bodylift lately, and sins then I've got problems with the auto tranny shifting...
Beside that, everything works OK.
« Reply #3 on: December 22, 2004, 03:02:53 AM »
   I have a connector similar to that on my '92 that doesn't go any where.  I believe Wild's right in that its for diagnostic purposes.
Offline chet
  • 556
  • Zuki time!
« Reply #4 on: December 22, 2004, 03:27:08 AM »
I think its for the AC I have the same 4 prong plug but its attached to an AC fuse and solenoid or something.
« Reply #5 on: December 22, 2004, 03:29:46 AM »
   ??? My AC still works with that connector unplugged.
« Reply #6 on: December 22, 2004, 03:36:27 AM »
That is the same area that cruise control is mounted on my 2wd. If you do not have cruise, it may be the facory plug for cruise.
Offline SnoFalls
  • 1358
« Reply #7 on: December 22, 2004, 03:47:01 AM »
Looks like the diag plug to me
My 91 has 2 plugs right there one is the diag plug (mine has a rubber cap that mighta been lost on yours) I also have a plug for wht I believe is the TCC relay (I see yours in the pic that I don't have)
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #8 on: December 22, 2004, 09:02:50 AM »
My 92 has one such plug and it's a diag plug, i used it allready but as SnoFalls says there's a rubber cap on it
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline DoRoN
  • 1990 Kick
    • Doron 4x4
« Reply #9 on: December 23, 2004, 12:05:09 AM »
Thanks for all yore help, guys  :o
It's the diagnostic plug alright.
While searching the web for an answer, I ran into this PDF file:
http://www.carsoft.ru/avtorepair/suzuki2.pdf
At page 4 (Fig. 3), you can see the plug.
The file contains a lot of info, that I think you all can find it handy.
BTW, in the file they are referring to 2 types of Sidekick, TBI and MPI.
what is the difference between them?
« Reply #10 on: December 23, 2004, 01:36:10 AM »
  The TBI is single throttle body injection on the 8 valves and the MPI is the multi port injection of the 16 valves.
   Thanks for the link to that article!
« Last Edit: December 23, 2004, 01:43:29 AM by LilRed »
