Speaking of plugged up EGR systems...
  • 9 Replies
  • 3783 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: April 14, 2007, 08:55:53 AM »
Does anyone know where that old article, or informational post (I can't remember which) went, where the guy explains how to clean out his EGR with like a hanger, or something?
Does anyone even know what I'm talking about?
Heather Galvin
Re: Speaking of plugged up EGR systems...
« Reply #1 on: April 14, 2007, 10:37:18 AM »
I can't remember the post. The EGR has a passage that goes through the head at the back of the block. IIRC I had would have had to have the exhaust manifold off to clean it out (used engine no manifolds fitted), that was on a carbed 1.6 so it might be different on an EFI without the mechanical fuel pump. Pic below is the EGR passage from the exhaust side.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #2 on: April 14, 2007, 09:23:05 PM »
Hi Heather,
Mine plugged up at the head end of the steel tube that goes from the EGR valve to the head.  I didn't remove the EGR valve, just the tube.  It's two 10mm bolts on each end to remove the tube.
The problem is that the port in the head was also packed with carbon, so just clearing the tube won't help.  You have to clear out the passage in the head too.  I just used a piece of copper wire because it was the tool available at the time.  A little Gumout carb cleaner helped too.
Jim Z.
66 Apache camper
Offline KickTurn
  • 53
  • My wife likes the smell of petroleum products.
« Reply #3 on: April 15, 2007, 01:30:52 PM »
But jzap, won't that just knock the crud back into the head where it can cause problems later by blowing back towards the EGR valve.  Wouldn't you have to pull the head to get it all out?
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
Offline urbanwheeler
  • 696
« Reply #4 on: April 15, 2007, 08:58:51 PM »
The port goes through the head from the exhaust manifold to the intake side. BTW, Was the carbed 1.6 better than the efi version? it just seems to me that the carbureted version of the 1.3 was a lot more fail proof than the efi (engine computer failure stops the from running). I just wonder if the same is true for the 1.6.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: April 16, 2007, 04:41:22 AM »
Yep. the best way to clean this is to remove the whatever is connected to either end of the passage through the head and clean/scrub it out with a solvent.  On the exhaust side, that would be the removal of the exhaust manifold.
Urban, I am not sure that there ever was a carbureted 1.6 engine.  Throttle Body Injection but not Carbed.  Folks like myself run 1.3 heads with Webers/whatever installed on 1.6 blocks.
Ack
« Reply #6 on: April 16, 2007, 04:44:33 AM »
Debatable, the carbs are pretty complex, similar to the later Samurai carbs. They wear out same as anything else. I don't think the mechanical fuel pump is any more reliable either. I can repair the EFI no problems but finding the right size pipe for all the different vacuum operated functions on the carb is next to impossible  ::).
« Last Edit: April 16, 2007, 04:51:13 AM by Rhinoman »
Offline Amilla
  • 1076
« Reply #7 on: April 16, 2007, 08:04:51 AM »
Its a jungle of VAC lines on the 1.3 sammi engine, and if you have ever tryed to re-build a sammi carb, its a duzy.
Can i clean out my EGR port by just removing the exhaust manifold? Or should i pull off the intake manifold also?
Amilla
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #8 on: April 16, 2007, 10:25:38 AM »
Thanks for the info, guys. ;)
I've had the stupid check engine light come on and off from time to time and the code is always EGR.
I'm just getting tired of it.
Heather Galvin
Offline jzap
  • 515
« Reply #9 on: April 16, 2007, 07:38:42 PM »
Urbanwheeler had the answer to that.  This is the tube to the intake side.
Most of the blockage was in the tube, whick could be cleaned out completely.  I used a stranded copper wire like a wire brush and cleaned out the head port the best I could.  I also used a fair amount of carb cleaner in it.  This was almost two years ago, and haven't had any further  problem.
Jim Z.
66 Apache camper
