track/kick OME struts - longer then stock?
  • 1823 Views
Offline lacrosse10604
  • 50
« on: April 14, 2007, 08:26:09 PM »
Are the OME struts longer then the stock ones?
Trying to decide if I really need them for my suspension lift, GV OME springs in the front & Kick OME springs with spacers in the back. I plan on flipping the strut mount to get more downward travel.
Searching for a donor for my diesel build.
Re: track/kick OME struts - longer then stock?
« Reply #1 on: April 15, 2007, 05:41:21 AM »
Yes, they're about 1 1/2" longer than stock. They also have camber correction built in.
Offline museboy07
  • 641
« Reply #2 on: April 15, 2007, 10:31:37 AM »
camber correction? how'd they pull that off in a strut? Is the hole just slotted?
« Reply #3 on: April 16, 2007, 04:56:27 AM »
The mountings are slightly offset compared to the stock strut. Its not adjustable as its only really intended to work with their 1.5" lift kit.
