Trans bearing or throwout bearing?
  • 2821 Views
Offline ExitLeft
  • 37
« on: April 19, 2007, 03:51:30 PM »
Just picked up a '94 Sidekick JX from a relative.  He gave it to me for nothing because he was too lazy to fix it or sell it.  He told me all it needed was a clutch job.  It has 145k miles on the origional clutch.  The symptom is that it whines like hell when the clutch is out, but is quiet when you push the clutch in.  Everything's origional on this car; engine, trans, t-case, clutch.  I haven't driven it around yet so I don't know if it makes any noise in any particular gear, but he says that the whining goes away once the 'kick warms up.  Sound like a bearing in the trans or a throw-out bearing?  I've searched this and a few other suzuki forums and found both explains the sound.  Any ideas?
Thanks,
WES
Offline ROSS
  • 1412
Re: Trans bearing or throwout bearing?
« Reply #1 on: April 19, 2007, 04:00:46 PM »
if you push the pedal to the floor and it stops whining its the trans bearing
Offline ExitLeft
  • 37
« Reply #2 on: April 19, 2007, 04:08:52 PM »
That's what I thought, too.  Is it time for a rebuild/replacement?  What about draining it and adding fresh fluid (it's probably never been changed!)?  Maybe adding some Lucas Oil to the new fluid?  Any other ideas?
Thanks again,
WES
Offline ROSS
  • 1412
« Reply #3 on: April 19, 2007, 04:13:26 PM »
oils cheap . i'd try it. when i got mine i drained the oil. it had alot of water in it.
it almost looked like mud.  flushed it out good and now its fine
Offline BigPig
  • 276
« Reply #4 on: April 20, 2007, 11:55:19 AM »
Mine does the same thing and it whines when driving in 5th gear.  Neither are too bad yet and I don't get many miles on it so it'll wait till I go through the engine.
'89 Sidekick w/ 4.5" of lift.
Offline PHX96TRACK
  • 90
« Reply #5 on: April 22, 2007, 12:01:21 AM »
Mine does this when cold. I warm it up with the clutch pedal to the floor and it makes no noise and after warm it's fine. Hoping it will not be a problem for a while
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
Offline ExitLeft
  • 37
« Reply #6 on: April 22, 2007, 03:34:16 PM »
Same thing here....why does it stop when it warms up??  Wouldn't a bad bearing still be bad regardless of temp?
WES
Offline PHX96TRACK
  • 90
« Reply #7 on: April 22, 2007, 10:49:12 PM »
My guess is when what little lube there is left gets warm, it lubricates better and the noise goes away.
