Side gears. chromoly shafts.
  • 1512 Views
speedball1981
« on: April 20, 2007, 12:25:51 AM »
 >:D
I have finally decided the newfeilds are the way to go for me...  I broke an axle shaft,  (w/o a ring)  and I brokr the inner race on a ringed shaft.  I want to know if anyone knows if I can use the ame locker,  (kwik lock)  or if I haveto buy new,  or runa different set up
Offline copperzuk
  • 38
Re: Side gears. chromoly shafts.
« Reply #1 on: April 20, 2007, 10:00:22 AM »
 All you should need are a set of rear side gears to put in the ft carrier, or put your locker in a rear carrier.
« Reply #2 on: April 20, 2007, 10:09:53 AM »
With the hardened front shafts you need to use the larger side gears from the rear end of the Samurai.  You can either get a rear end with a locker in it or just buy a locker for the rear end with side gears.
If you are referring to the Kam Locker then I don't believe you can use it in the front end.  Maybe if you had some custom front shafts made up, but the Kam uses custom rear shafts.
