T-CASE SEALS
  • 1642 Views
Offline 96track
  • 66
  • THESE JEEP FREAKS WILL NEVER LEARN!!!
T-CASE SEALS
« on: December 20, 2004, 01:30:27 PM »
hey guys where are the t-case seals located on a 96 tracker auto and can I change them without dropping the case.
96 track  2 inch susp, 3 inch body,512's, 4.24 to 1, rear locker, 31x12.50 boggers, warn 8000, custom front and rear bumbers. lined and diamond plated interior.
1988 sammy  spoa with cj's rear and rears up front, 4.16, rear locker, 31x 12.50 boggers, full cage by migoffroad .com
the silver sammy is mine, they use it as a display for there cage work.
Re: T-CASE SEALS
« Reply #1 on: December 20, 2004, 04:15:49 PM »
The only seals that you can change from
outside the case are where the driveshafts
come out, and yes they can be changed
easily once you drop the shafts
