Vibrations
  • 2123 Views
FarFetchedZUK
Vibrations
« on: April 23, 2007, 01:05:11 PM »
I got my Zuk running. It runs but missing.It runs very rich (feels like one or two cyl not up to par) I haven't gotten compression mesured yet. I suspect engine is weak. Nevertheless, I drove it and I feel horrible vibes going 30mph and then 55mph. Feels like vibes are felt throught t-case shifter. I've disconnected rear d-shaft, drove it likt that, still there.
I have a lot of experience with Jeeps (owned one for 8 years), but not much about gear driven t-cases where gears are used to transfer HI range 2WD. Another Q is how often transmission to t-case shaft go bad, is it possible to have it out ob ballance?
Also, could rough running engine transmit vibration through the driveline, seems unreal, however, I don't exclude that possibility.
Please advice on wether I should R+R t-case and rebuid it!
I would like to see owners with similar problems pitch in!
Cheers!
Offline jeff1997
  • 1228
  • 27
Re: Vibrations
« Reply #1 on: April 23, 2007, 06:38:41 PM »
Not sure what Zuk you have have, but the motor mounts may have come a little loose from the rough running motor and that could transfer the vibes to the rest of the vehicle, ?maybe?
3" Masterkit1 body lift
Custom strut spacers
Offline Vagabond
  • 95
Re: Vibrations
« Reply #2 on: April 23, 2007, 08:48:34 PM »
Are you sure that your drive shafts are in phase?
[/url]
FarFetchedZUK
Re: Vibrations
« Reply #3 on: April 24, 2007, 01:11:00 AM »
That's the first thing I have checked - and they weren't. I put them back phased properly.
I'll check motormounts!
Cheers!
FarFetchedZUK
Re: Vibrations
« Reply #4 on: April 24, 2007, 02:18:59 AM »
HOLLY CRAP!
I have never seen such profound lack of maintenance.... :o
I've replaced u-joins with maybe .005 of play( i was realy anal about my Jeep before).... NO - these u-joint are simply shot to DEATH!
Especially transmission to T-case (t-csae side u-joint has about 2/32 of play SHIZER!!!)
I'will get U-joints ordered in a timely maner!
I can't complain about my 87 Samurai - I got if for FREE  ;D
So I will have to sink some $$ into it!
Cheers!
« Last Edit: April 24, 2007, 02:20:30 AM by FarFetchedZUK »
Re: Vibrations
« Reply #5 on: April 24, 2007, 08:48:42 AM »
I noticed my Sami looked like it hadn't been body-lubed in YEARS. It's why I change my own oil now - the "techs" at oil change places always miss something with thier grease gun.
-Jeremiah
