geo metro 1.3l into suzuki samurai?
  • 21 Replies
  • 13161 Views
Offline mcgyver
  • 17
  • Sammy's kill jeeps!
« on: December 13, 2004, 06:21:02 AM »
Can a geo metros 1.3l engine be used as direct match to a samurai's 1.3l ?
Offline DirtDevil
  • 317
  • Island4x4.com
Re: geo metro 1.3l into suzuki samurai?
« Reply #1 on: December 13, 2004, 06:50:32 AM »
arnt they front wheel drive?
« Reply #2 on: December 13, 2004, 07:47:12 AM »
Metro has a 1.0L 3 cylinder
Swift GT was a 1.3L 16V 4
cylinder with 100 HP
:D
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #3 on: December 13, 2004, 11:04:38 AM »
It can if it is a 4 cyl 1.3 ltr. It will work with some basic mods like the oil pan, intake and exhaust.  Maybe the distributor as well.
« Last Edit: December 13, 2004, 11:05:26 AM by j2custom »
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline Cwkick
  • 888
« Reply #4 on: December 13, 2004, 12:12:09 PM »
Yes it will work!!
I ordered an engine from Unitex Trading Company
http://www.unitextrading.com/
a couple of years ago.  It showed up as a Swift engine.  I had to remove everything from the Sami engine and swap it onto the Swift engine.
The Sami is still running great!
Cwkick
Offline szabotage
  • 114
  • snaggletooth
« Reply #5 on: December 13, 2004, 12:49:06 PM »
the water outlet on the intake will be facing the firewall instead of the radiator when mounted into the samurai so a longer hose will be needed to reach. all other components will bolt together tho.
not sure bout the disty, I forgot if its like the GTI motor or not and if it is you'll have to do the mazda 323 GTX cap and rotor or carve out a section from the firewall for clearance.
mike
« Reply #6 on: December 13, 2004, 01:03:08 PM »
If you swap the intake it shold be
the same as a stock 1.3L Sammy
I was going to put a 1.3L from a
Suzuki Car in the Sammy, but the
intake was different, and the EFI
wouldn't fit on the Sammy intake
manifold  >:(
Offline kansascitytracker
  • 335
  • 92 Tracker
« Reply #7 on: December 13, 2004, 03:17:07 PM »
I used to have an Isuzu Stylus (same as a Geo Storm), that little thing had some pep, but I can't remember if it had a Geo or Suzi engine or an Isuzu engine. I do think it was a 1.3 or 1.6 though.
« Reply #8 on: December 13, 2004, 03:43:02 PM »
GEO was just the badged name,
it was an Isuzu with an Isuzu
engine, here is a funny twist
Isuzuki
What Do Ya Think ???
  • 335
  • 92 Tracker
« Reply #9 on: December 14, 2004, 11:24:24 AM »
I find it funny Isuzu made the Geo Storm, Toyota made the Corolla and Prizm, and Suzuki made the Metro and Tracker. The GM pres must have his hand in everyones pockets back in the day. GM announced yesterday a joint venture with Chrysler to make hybrids. Don't see 2 American companies get together very often.
Offline SnoFalls
  • 1358
« Reply #10 on: December 14, 2004, 11:40:13 AM »
chrysler isn't an american company, what gave you that idea ...
« Reply #11 on: December 17, 2004, 12:21:22 PM »
Not any more at least
mudfkr
« Reply #12 on: December 17, 2004, 03:17:19 PM »
I swapped a G13 out of a FWD swift in to my mates '86 SJ413 and from memory theres a difference in the distributors and the  housing on the back of the motor, I think the swift has a shorter distributor and housing  ??? Either way one won't fit into the other.
One other thing you need to change is the water pipe running along the R/H/S of the motor as thats different as well.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #13 on: December 17, 2004, 03:27:41 PM »
GM and Ford are working together on a new 6 speed automatic transmission to catch up with the Japanese.
Geo and Asuna were two of the biggest blunders GM had ever created.  I'm sure the exec who though those nameplate up was show the door mighty quick in Detroit...LOL
Offline mcgyver
  • 17
« Reply #14 on: December 18, 2004, 05:28:44 PM »
Thanks all for the input, I was able to find a samurai motor/donor truck for $200. I'm going to take the hood and the engine. The owner said If I sell the rest of the truck he'll cut me a deal. anyone need and parts cheap? I'll make sure this works out for all.
