?? about 99+
  • 1679 Views
Offline biker
  • 730
  • It's a sickness I tell ya
?? about 99+
« on: April 27, 2007, 07:53:11 AM »
I currently have a 91 2 door for offroad only and a 94 4 door for a daily driver and am very happy with them but I would like to upgrade into a 99+ tracker or GV for daily driver duties. What should I look out for on the newer ones, any inherent problems with them? Is a 2inch lift easy to do for cheap, just for looks will not be offroaded, I have my 91 for that.
Thanks for any info you can share
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline bzzr2
  • 1011
Re: ?? about 99+
« Reply #1 on: April 27, 2007, 08:38:28 AM »
2 inch lift will be the same except you cannot flip the strut mounts.  otherwise i can't suggest anything to watch out for.
09 taco reg cab short box 4x4
Offline stone
  • 86
  • offroaders a built not bought
Re: ?? about 99+
« Reply #2 on: April 27, 2007, 10:08:25 PM »
check out the front cross member there known to rust.. if the one ur getting is in good shape i suggest removing the cross member and givin it a good coat of rust protection inside and out
