Factory Rear Overload Spring Flip???
  • 1956 Views
copperfever
« on: April 28, 2007, 02:53:26 PM »
Hey all,
I've been in "lurk" mode for a while on this forum, and finally decided to ask a question!
I have an '88 Suzuki Samurai, all stock for the time being. Has anyone ever flipped the rear overload springs over to lift the rear(to save money instead of getting a set of add-a-leafs)? I was thinking of also adding a set to the front. I know that they would have to be cut-down/played with a little for it to work...
Offline Element
  • 1902
  • LillyKicker
Re: Factory Rear Overload Spring Flip???
« Reply #1 on: April 28, 2007, 07:41:21 PM »
Lostsamurai has done this... I will let him know you are looking for info!!!
zUkTAH
U4WDA
copperfever
« Reply #2 on: April 29, 2007, 10:14:33 AM »
That would be awesome. I really apreciate it!
copperfever
« Reply #3 on: May 02, 2007, 01:37:47 PM »
Anybody have any info to offer? I am on the verge of just starting in with the PB Blaster and angle grinder...
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #4 on: May 02, 2007, 05:54:35 PM »
This is lost, all you need to do is grind off the bolts (spring pack and the little c shaped bracket) flip the helper, and the c shaped thing and replace the two bolts, you may have to place all the leafs in a vice so they will stay compressed long enough to get the bolts in, ive done this on the rear to prevent axle wrap, and then i put a set of rear springs on the front of my sami and did the same to them. any q's just ask sorry it took so long to get back to you i thought the post was on zuktah's forum.
copperfever
« Reply #5 on: May 02, 2007, 06:39:35 PM »
Sounds simple enough. Did you end up getting much lift out of it?
Thanks!
