may have lost clutch any suggestions?
  • 1904 Views
Offline westvilleguy
  • 53
« on: May 01, 2007, 01:43:47 PM »
i pulled out of a gas station and noticed i didnt have any acceleration my tracker would rev up but barely speed up finally got going cruised along fine on the highway when i pulled of same problem. then when i got to town i could barely get any speed had to go like 20-30 kmh reving really high to get it to my parents place pulled it in the field by their house now it wont go anywhere clutch pedal still feels the same any suggestions on what this could be?
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
copperfever
Re: may have lost clutch any suggestions?
« Reply #1 on: May 01, 2007, 03:19:07 PM »
Try adjusting it. If there is no free play in the pedal then the clutch might not be engaging the flywheel fully. If that doesn't work, you probably need to do the clutch. But hey, the transmission is small and light, Samurais/Trackers are tall enough to get under easily, and clutches are pretty easy to do(especially with a shop manual)!
  • 53
« Reply #2 on: May 01, 2007, 03:36:58 PM »
wheres the adjuster? is up by the pedal?
Offline offlimits4wd
  • 76
    • offlimits4wd.com
« Reply #3 on: May 01, 2007, 05:12:15 PM »
At the end of the clutch cable connected to the trans. But sounds like the clutch is bad.  The cable adjuster would have to tighten up to make it slip. If it loosens up you can still drive it but its hard to shift. Hope this makes sense.
g-man
« Reply #4 on: May 01, 2007, 07:11:06 PM »
I have never pulled the trans on my sidekick but have pulled the engine about four freaking times. From looking at the bottom side with the married transfer case and linkages and the shift tower and everything else you would have to pull I would almost say if you had a cherry picker it would be easier to pull the engine to change the clutch. I just use a chainfall from the rafters in the garage and remove the hood.
I put a trans in a samurai once and it was pretty easy because it has a divorced transfer case but the tracker/kick would be more involved than that. What does everyone else think?
Trackin92
« Reply #5 on: May 02, 2007, 06:48:19 AM »
Sounds like the clutch went out to me. Same thing happened to me when mine went out. Came home the night before worked fine and everything, next day get in start to drive away and I had to rev up just to get somewhere. This being my first manuel car and also first car I had no idea what it was. So i just drove to the shop to avoid a towing charge but it ended up going out about a block away lol
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #6 on: May 02, 2007, 06:11:17 PM »
It is much easier to pull a tracker or sidekick engine to change the clutch but once you pull it the clutch only takes 10 min  to change
