Head Bolt Torque and Pattern
  • 9 Replies
  • 4535 Views
Offline speedytang
  • 78
« on: May 01, 2007, 08:41:01 PM »
I need the bolt tighten sequence. I do remember that it is 54ftlbs but don't own a Tracker book since everything is of simple design. Thanks.
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: Head Bolt Torque and Pattern
« Reply #1 on: May 01, 2007, 10:33:25 PM »
might track down acks web site and see what he has. Lots of info on it.
found it
http://www.acksfaq.com/
Mean Green Wheeling Machine
Offline speedytang
  • 78
« Reply #2 on: May 02, 2007, 12:19:04 AM »
I have tried that site and all I get is a error when searching.
Offline ROSS
  • 1412
« Reply #3 on: May 02, 2007, 07:36:54 AM »
go to your local auto parts store and buy a chilton or haynes manual.
thats the first thing i did when i got my sammi.
it gives you everything you need to do anything.
Offline speedytang
  • 78
« Reply #4 on: May 02, 2007, 11:54:39 AM »
Those repair manuals are a waste of time. They are such a simple design and all I need is the head bolt torque pattern not worth the $20 for one item.
copperfever
« Reply #5 on: May 02, 2007, 01:56:07 PM »
They often stock chilton and haynes repair manuals at the library if you don't want to throw down for one...
Offline speedytang
  • 78
« Reply #6 on: May 04, 2007, 07:11:15 PM »
No auto part store has the Tracker repair manual and the library was a bust also. Can some scan the bolt torque pattern for me. I am pulling the head in the morning and still need the pattern. Thanks
Offline ROSS
  • 1412
« Reply #7 on: May 04, 2007, 09:13:39 PM »
if they're a waste of time . why do you want information out of them???????????
if I get a chance tomm. i'll scan and post it for you
« Last Edit: May 04, 2007, 09:17:31 PM by ROSS »
« Reply #8 on: May 05, 2007, 07:28:06 AM »
AFAIK all torque patterns are the same, you start with the inner most bolts and then work outwards in a diagonal pattern. It doesn't really matter which ones you do first as long as you follow that pattern. Torque the bolts down a bit at a time and then repeat the sequence. The Track/Kick manual is downloadable at :
http://www.suzukiinfo.com
The torque setting is 51-54ft.lbs. It is important to note that the threads on the bolts should be given a thin coating of clean engine oil. If you don't do this you won't get the correct torque.
« Last Edit: May 05, 2007, 07:35:12 AM by Rhinoman »
Offline speedytang
  • 78
« Reply #9 on: May 05, 2007, 09:30:50 AM »
Thank You, At least someone is of help.
