86 zuk mods
  • 2237 Views
yzchamp
86 zuk mods
« on: May 01, 2007, 11:01:40 PM »
got  this thing  fev days a go   its  a rust  bucket     but  i  wanna fixed up  and make  a hunting  vehicle out  of it..so  i'm  thinking of  a lift   and a biger  tires
for lift  im  thinking  of  a SPAO  to  get  more clerance    and looks like is the cheapest too  whats  the highest  i  can  go  withour moding    brake lines drive lines  and pitmans arm?
as  i mentionet  before  its  a rust  bucket  so  i'm  thinking  of replacing  fenders  with  diamond aluminum   plate  but  before i  do that  i  was wondering if  any  one has seen any thing like it  and if it looks alright( i  get  it for free).  pictures would  help ... so  please drop me a line  to  help  me   with  decisions!!  thanx
yzchamp
Re: 86 zuk mods
« Reply #1 on: May 02, 2007, 08:24:10 PM »
anyone?
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: 86 zuk mods
« Reply #2 on: May 02, 2007, 10:45:36 PM »
highest you can go with out changing anything but height depends on how much metal you want to cut off your rig. If you want to do a lift you are going to have to mod after 1 or 2 inches.
SPOA requires new brake lines new steering new shocks.
Mean Green Wheeling Machine
Re: 86 zuk mods
« Reply #3 on: May 03, 2007, 06:40:38 AM »
You can get away with your stock shocks if you swap your spring pads to the opposite side.  It is a way to stay on the cheap with your SPOA build.  With your brake lines you can cheat and move them outside the mount on the frame and use a zip tie to keep them from floating around, but longer ones are recommended.  This said, you should save up and fix the steering like Bash mentioned.  One half of the Sky setup works perfect, but you can bend up your cross bar if your not careful.  I ran a stock bar at Johnson Valley (To lazy to put the heavy duty one on during an axle swap) and it has a big old frowny face on it now.  Even rubs on the springs.  :P
If you are careful you can actually do a SPOA by cutting off your existing pads and re-welding them onto the top of the axle.  I would spend the extra 100 though and buy the Rocky-Road Spring pads as they make it a lot easier to put things together.
I originally ran 33" tires with a standard SPOA with some fender trimming in the rear and some work with a hammer in the front.  Stock shocks and brake lines.   For the rust problems on the rear, we actually cut out the rusty part of the fender and welded in a new inner fender.  It added about 2" of clearance in the rear.
Pic of older setup.
Of course, now I have a RUF setup with folding front shackles and F-250 shocks on the front end in order to get rid of the jack hammer ride, but the rear is still a standard SOA.  :P
Full Size Pic Linkage
