30 inch tires on Samurai
  • 6116 Views
bullit
« on: May 02, 2007, 11:19:04 AM »
Hello all, As you can see I am new to the forum. I have a 94 Samurai that I want to put 30 x 9.5 tires on. I am installing a Calmini 3.5 inch combo suspension kit. Most of my driving will be on road. My question is, will performance suffer from using larger tires and should I change the gear set.
Thanks in advance for any insight anybody can provide.
Bullit
copperfever
Re: 30 inch tires on Samurai
« Reply #1 on: May 02, 2007, 11:26:17 AM »
I had 31x11.50's on mine with stock gearing. 5th gear was pretty much usless on the highway, unless I was goind downhill. Cruising speed didn't really change, it was 55mph with stock tires, and the same with the 31's, just in 4th gear instead of 5th. It did fine off-road, once I put it in 4-Lo it had plenty of snort to spin the tires with ease.
bullit
« Reply #2 on: May 02, 2007, 11:29:07 AM »
THANKS!
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #3 on: May 02, 2007, 10:58:34 PM »
My opinion regearing is a good thing keeps clutches from burning up.  and allows easier turning tires.
Mean Green Wheeling Machine
copperfever
« Reply #4 on: May 03, 2007, 07:24:32 AM »
I would agree if we were talking about anything bigger than 31's. If you stick to 31's or less you will be fine with the stock gearing.  32's or larger you should at least re-gear the t-case if nothing else.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #5 on: May 03, 2007, 07:31:42 AM »
Yep 31's or less you will be fine...
