94 tracker drive it without rear a-arm hooked up?
  • 2032 Views
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« on: May 03, 2007, 09:07:16 AM »
I lifted my 94 tracker and in the process of replacing the a-arm spacer I made with a better designed one I broke off 3 bolts into the diff (got another diff with 5.12's coming) not a big deal since I was getting new diffs to upgrade to 5.12s' from 4.62's anyhow.  But here is the deal I have about a 200-300 foot driveway. I need to move the tracker about 150 feet would it be a big issue if I drove it without the rear a-arm spacer to where I need it to be?
would be nice if I didnt need that damn thing, I miss driving my truck until my new parts get here.
Re: 94 tracker drive it without rear a-arm hooked up?
« Reply #1 on: May 03, 2007, 09:50:03 AM »
Without the rear A arm fitted I wouldn't risk it. The rear axle is likely to rotate and rip out the prop and brake lines and also bend the shocks. I guess that you could lash it in place but I'd still be inclined to get a few friends round and push it.
Offline chrisvitarasport94
  • 228
« Reply #2 on: May 03, 2007, 11:01:37 AM »
don't do it!   My 2" spacer on the rear diff failed coz it was a solid block with 3" bolts that were too long and not up to the strain; I had to drive it very slowly to the road to get recovered; body sways laterally, and risks of twisting the axel etc
Offline bus_driver
  • 479
  • the voices tell me different things
« Reply #3 on: May 03, 2007, 07:41:50 PM »
hey could you take the rear drive shaft out and only use the front shaft essentially just pull the rear end ...
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
« Reply #4 on: May 07, 2007, 12:30:49 PM »
That doesn't sound to bad it would proly be the way to do it. I dont see any problem with it cause there wouldnt be and torque going to the rear. This may sound dumb but the problem i would see with that is possibly when you hit the brakes. but the rear only does like 10-15 percent of you braking so i dont know.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #5 on: May 07, 2007, 07:01:24 PM »
your asking for shock damage no matter what you do.. I have broken that piece. the shocks get trashed.. Good luck
