electrical short issue
  • 1979 Views
Offline blackzuki90
« on: May 05, 2007, 12:28:49 PM »
I have read through the search about more than  a few people having electrical shorts in their
system. Im having one where the power drain is pretty bad  my alt will almost want to seize and im forced to turn my lights off for a min to let the alt catch again at idle. I have swapped the harness behind the dash and didn't help at all. What are some of the solutions people have discovered in this mess...this is probably the most annoying problem I have yet to encounter !|removethispart|@ >:(
copperfever
Re: electrical short issue
« Reply #1 on: May 05, 2007, 01:43:51 PM »
Are you running "extras," like aux. lights, sterio amplifier, subs, etc.? If so, you may want to look into a GM alternator conversion...
« Reply #2 on: May 05, 2007, 02:44:33 PM »
Thats a pretty big short. I would have thought that in most cases that would have burnt something out. Could it possibly be a faulty battery?
Offline blackzuki90
« Reply #3 on: May 05, 2007, 08:26:14 PM »
well she has had 3 different batterys in her and she doesnt like anything ! i know for sure though that all 3 cant be bad....I will probably end up changing out most of the harness just to figure it out !!
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #4 on: May 07, 2007, 10:42:52 PM »
have you tested the charging system yet? when you say that it is at idle it wants to stall if you have any lights or heater on? if you are going thru batteries so fast the alternator could be over charging. check for charging voltage at the battery with the truck running and all accessories off. anything over 14.6 volts means that the alternator is over charging and that will cook the battery.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline blackzuki90
« Reply #5 on: May 07, 2007, 10:45:44 PM »
i have just replaced the alternator and it tested good what i noticed is if i run the car with no batter hooked up its fine now belt whining nothing the min a hook it up its ok but it will start whining the belt pretty hard when the lights are on and i get to a complete stop. I think something is shorting to the block somewhere... jees what a pain in the ass !.
« Reply #6 on: May 08, 2007, 05:13:34 AM »
Do the lights work?
