samurai motor biuld up suggestions
  • 1524 Views
speedball1981
« on: May 06, 2007, 09:26:35 AM »
I'd like to get a little more power from my 1.3,  I don't really know what the factory rating is,  i think 55 horse, and 75 ft lbs?  its a carbed 88,  i want more power for rock crwling at slow speeds, and more wheel speed for hill climbs,  I already have the 4 to 1 t-case,  and I don't went to change to a different motor,  I have 2 extra 1.3's  sitting in my garage...   I have had bad luck in the past with carb swaps,  so i'd like to keep the factory carb... or maybe throttle body it if any body makes a kit...
I'm thinken cam it, and a header,  and electric fan,  might give me the desired results?
but I kind want to know about what kind of work on the head I can have done?  what cam grind is good,  any other companys out there that deal with this stuff?? etc.
or  just some simple suggestions...
thanks
Re: samurai motor biuld up suggestions
« Reply #1 on: May 06, 2007, 12:40:59 PM »
If you want more power then you will need a bigger carb or a good sized TBI. The Weber makes a lot more power because it is significantly larger. If you're doing hillclimbs then I wouldn't suggest that. I would look at fitting a Track/Kick TBI with a custom ECU, maybe a Megasquirt. I doubt that you'll see much from the electric fan but a good header and cam would liven it up. From previous posts that others have made it would seem that the Thorley header and an Isky cam is a good setup.
Head work I don't know, clean up the ports and maybe fit the larger 1.6 valves. I'm pretty sure Zaggy did a fair bit of work on a 1.3, he doesn't post very often now but you could PM him.
Offline dsumers
  • 72
« Reply #2 on: May 08, 2007, 10:15:00 PM »
I have build lots of 1.3's, I think the best thing you can do to the 1.3 is to have the machine shop install 1.6 valves, and port the head as well.
