Removing rear halfshafts vit/kick
  • 1773 Views
Offline skandy32
  • 93
  • Zukiworld Rocks!
    • Andy Colver Photography
« on: May 07, 2007, 10:46:56 AM »
Having trouble removing the rear halfshafts....
Was given a veichle without the rear diff as it was knackered and removed, so obviously the shafts have come out at some point. Just rebuilt a new diff ready to fit - but cant get either shaft out to put it in!
Undone all the bolts, all around the drumbrake too, as the haynes manual says.... but they wont budge. Even tryed 'towing' it out with another vitara! ha! Must be something i've missed... Help please!
Is it just a case of pulling/ forcing it out after undoing alll the bolts??
UK Vitara - 2" spring/shock spacers, 3" calmini body lift, 32x11.5x15" BFG MTs, rear half calmini exhaust/no cat, full Alpine ICE
http://www.andycolver.co.uk
Re: Removing rear halfshafts vit/kick
« Reply #1 on: May 07, 2007, 11:23:31 AM »
The bearing is a tight fit (or at least should be). A slide hammer on the end of the shaft is the preferred method but if you haven't got one try bolting the wheel back on and giving it a jolly good kicking.
« Reply #2 on: May 07, 2007, 03:57:53 PM »
 :) You Brits are fun to listen too! " ... a jolly good kicking," Thats priceless.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #3 on: May 07, 2007, 06:58:54 PM »
on the older models with the 4 center studs on the axle. Pull the brake drum. Flip it over and put  it back on the studs. Tighten two nuts on about half way and use the drum as a slide hammer.. not the best for the threads but it works.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #4 on: May 08, 2007, 05:14:09 AM »
Yeah, slide hammer is the shiznit...  cheapo here in the States, at Harbor Freight...
even with the slide hammer, I had to give mine a JOLLY good "wonking"
