Aluminium coil spacers?
  • 2768 Views
Offline hap
  • 38
  • huh?
« on: May 07, 2007, 04:31:14 PM »
I am looking for a more durable coil spacer then the poly I have been using. Does anyone know of a aluminium spacer in production for our trucks?
Thanks
Offline bzzr2
  • 1011
Re: Aluminium coil spacers?
« Reply #1 on: May 07, 2007, 06:57:30 PM »
r u having problems with your current spacers?
09 taco reg cab short box 4x4
Offline hap
  • 38
  • huh?
« Reply #2 on: May 08, 2007, 04:34:47 PM »
After having them on for under 8000 kilometres I have lost close to a half inch of lift up front. The spacers don't look in very good shape, so I can imagine how they would be after another 8000k.
No one knows of a aluminium spacer?
Offline IanL
  • 466
« Reply #3 on: May 10, 2007, 01:23:20 AM »
I wonder whether the only satisfactory metal in that environment would be stainless steel?  I'm thinking of corrosion.
Offline 90Stomper
  • 427
« Reply #4 on: May 10, 2007, 09:03:16 AM »
http://www.vttr.com.tw/e4X4.htm
found this when looking for snorkels.  dont know who they are but they have aluminium spacers....
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline bzzr2
  • 1011
« Reply #5 on: May 10, 2007, 09:34:47 AM »
i've easily lost that much all around, it's just the stock springs wearing down from the off roading as far as i can tell.
my spacers are showing no wear, they are made of the hard white plastic stuff, whatever that is.  maybe somebody who makes them can get you a few of those made up for cheap...
Offline Davyboy
  • 252
  • I eat CR-Vs and Rav4s! Mmmmm...yummy little AWDs!
« Reply #6 on: May 12, 2007, 10:00:45 AM »
How about this....and it's a little closer to home than VTTR in Taiwan:
http://www.masterkit1.com/Vitara%20GV%20Tracker%2099-05/Vitara%2099-05_ang.htm
It's steel, though, not aluminum.
1999 Grand Vitara w/CALMINI Suspension and RRO Body Lift, 31" Goodyear MTR tires, Skidplates, 5.12 Diffs with a Lock-Right in the rear.
Offline jeff1997
  • 1228
  • 27
« Reply #7 on: May 12, 2007, 12:34:35 PM »
The problem with most of the poly spacers is the plastic is too soft. I can make you 1.5" or 2" spacers from poly that are much harder, stronger and will not sag. Look on ebay under seller name: hoepkers. The 2" look just like the 1.5". I've ran them now for a year on my 97 4dr. and they have no sag, squish, droop, cracks, or any deformaty at all. I will sell direct so just let me know. My direct email is hoepkers|removethispart|@charter.net. Check the forum, others have bought mine and see what they think. And sorry to say but red is the only color I have.
3" Masterkit1 body lift
Custom strut spacers
