FJ 60 steering Gear
  • 1909 Views
Offline dsumers
  • 72
FJ 60 steering Gear
« on: May 08, 2007, 10:09:16 PM »
Im looking for some information on installing an FJ 60 steering gear in a samurai.  Any information, and pictures would be greatly appreciated.  Is there any difference between Fj 40 and fj 60 steering gears.. Anybody located in western washington looking to sell a steering gear?
Re: FJ 60 steering Gear
« Reply #1 on: May 09, 2007, 09:49:37 AM »
Do you mean the steering box or the hardware on the FJ axles?
Offline dsumers
  • 72
« Reply #2 on: May 13, 2007, 07:16:16 PM »
Steering gear is the proper name for what you may call a "box"
« Reply #3 on: May 14, 2007, 12:49:02 PM »
One way 6:1, the other way half a dozen to 1.  :)
You should be able to make it work, most people that want a heavier duty setup just go with the Toyota Mini Pickup setup, or a Tracker/Sidekick.
New mounts will have to be fabbed up.  A new turnbuckle setup to connect your existing steering to the new box.  Then splice your steering bar together, so your existing setup will have the correct ball joints at both ends.  Alternatively you can put a new end on the Pitman arm.
Make sure you will have proper clearance, you might need to reposition the box depending on how much travel the arm has.
Your probably doing a custom solution, but you might try checking out Trail Tough's selection of steering components.  They have some kits available for running Toy hardware on your Samurai.
http://www.trailtough.com/steering_components.htm
