Electrical Problem in 95 Tracker
  • 1815 Views
Offline Uncivilized
  • 1469
    • Car Domain
« on: May 11, 2007, 05:53:24 PM »
For a little backround, I previously had a proble with my parklights, and high beam on the passenger side, I had to run a jumper wire to fix, but now I have something wrong for sure, over the past week or so, I've lost low-beam/daytime running lights, horn, and my washer fluid doesn't spray. I adjusted my headlights all the way down so I can drive at night with my high beams on. I've checked all the fuses under the dash, and all are fine. Has anyone had a problem like this before? I don't even know where to start. I'm wondering if I have a chaffing harness somewhere, or if it's the control levers behind the steering wheel. Help Please!!!
Dave
g-man
Re: Electrical Problem in 95 Tracker
« Reply #1 on: May 11, 2007, 08:29:59 PM »
Check all your grounds.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: May 13, 2007, 12:20:20 AM »
« Reply #3 on: May 13, 2007, 08:56:44 AM »
Dave
Yep, bad ground.  Check G101 which is on the RH front engine compartment near the Washer Fuild reservoir.  This grounds the Right front park lamp & side marker, horn, washer pump, & daytime running lights!
« Last Edit: May 13, 2007, 09:17:50 AM by LilRed »
Offline Digger
  • 1991
« Reply #4 on: May 13, 2007, 11:15:58 AM »
Good job, LilRed! Can't get much more of a diagnosis than that over the net! LOL!
