94 Sunrunner 4X4
  • 20 Replies
  • 5605 Views
0 Members and 10 Guests are viewing this topic.
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
94 Sunrunner 4X4
« on: December 10, 2004, 12:49:25 PM »
When ever I put it into 4 wheel drive and turn the wheel all the way to the left or right and try to go forword or reverse the wheels always lock up, whats up with that?? ???
Sunrunner GT, Gold Trim Level
Re: 94 Sunrunner 4X4
« Reply #1 on: December 10, 2004, 12:52:23 PM »
Don't do that on hard dry ground,
you can damage stuff like that.
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #2 on: December 10, 2004, 12:54:05 PM »
what do u mean
« Reply #3 on: December 10, 2004, 12:57:15 PM »
4WD is for use on slippery surfaces,
ice, snow, dirt , gravel ect.  if you use
the 4WD on dry streets it binds up the
driveline and can snap U-joints, pop CVs
break Axles or even Frag your driveshafts.
Use the 4WD for traction when it's slippery
only, not just for driving
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #4 on: December 10, 2004, 01:01:48 PM »
Ya, when its snowy out side i use it. and when i do it always locks up, when i fully turn it
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #5 on: December 10, 2004, 01:02:44 PM »
I noticed it last year, winter
« Reply #6 on: December 10, 2004, 01:08:00 PM »
Are the tires hitting the frame ???
What size are they ???
Describe "locks up" better, what do
you mean by this, the engine stalls,
the tires stop turning, chattering tires
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #7 on: December 10, 2004, 01:11:42 PM »
the tires stop turning. no rubbing. they just will not turn until i start to straighten the stearing wheel
« Reply #8 on: December 10, 2004, 01:14:43 PM »
That's odd, I would say use a little more throttle,
but I bet you tried that, sounds like binding, but
I can't say I have ever had that problem  :-/
Offline 1bigtracker
  • 3409
« Reply #9 on: December 10, 2004, 01:16:04 PM »
is it all stock?
stu
« Reply #10 on: December 10, 2004, 01:18:15 PM »
Good Question
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #11 on: December 10, 2004, 01:18:38 PM »
I took it to my Pontiac Dealership where i bought it and they said everything looked fine. But to me it doesnt seen right :(
Offline SnoFalls
  • 1358
« Reply #12 on: December 10, 2004, 07:40:57 PM »
Sounds like a bad CV to me ...
Offline bandit86
  • 1641
  • elv8rguy
« Reply #13 on: December 11, 2004, 03:32:51 AM »
sounds like someone welded the diff???
lift the car up on the a-arms and rotate the wheels separately sided to side.  one of your cvs might be binding as well
Offline jzap
  • 515
  • How difficult can it be?
« Reply #14 on: December 11, 2004, 04:18:29 AM »
My '96 Tracker gives the same feeling of binding up, usually when winter driving and I get to a well plowed parking lot.
I just chalked it up to what Wildgoody said, that you're not supposed to use 4wd on surfaces where you have good traction.  I just don't use 4wd on pavement, even if its wet.
I click out the hubs and it's fine.  It also has never been a problem off road.
Jim Z.
66 Apache camper
