Anvil instal prep questions
  • 14 Replies
  • 4744 Views
Offline 90Stomper
  • 427
« on: June 15, 2005, 03:53:44 PM »
had CalMini send me a list of stuff needed to do an anvil instal(this fall i hope).  but....
driver's side long inner 26 axle from a 96-98 - i understand this
steel fron dif carrier from 99-04 GV - will my new 5.83 gears fit in this?  and can i still get a loc rite for it (which is the main reason for the anvil in the first place)
driver's side outer 1/2 shaft from 89-98 - i can use the one i have on the 90 now cant i?
why no mention of the pass side axel?
what else am i missing here?  thanks all 8)
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Re: Anvil instal prep questions
« Reply #1 on: June 15, 2005, 10:28:32 PM »
You will be able to run a locker in the front with the anvil set up. But you will need the sami carrier to install in the GV steel housing.
You will need your Drivers side half shaft you have now PLUS one more to use on the passenger side. The anvil replaces the weak passengers  side  half shaft with a stub shaft and a drivers side half shaft.
If you need a little guidance while installing Anvil or more info before ordering check out http://www.zukiworld.com/month_110103/feature_zigsbeef.htm
HTH,
Offline 90Stomper
  • 427
« Reply #2 on: June 16, 2005, 04:25:48 AM »
cool, i will check that out.  so your saying my gears will go in the sami carrier?  why didnt they put that in the list? :(
« Reply #3 on: June 16, 2005, 04:49:17 AM »
The Sami Carrier is not a must have for the Anvil install. The sami is a Locker install item. I am not sure if they make a bolt in locker fir the GV's or not. But with the Kicks/Trackers the stock carrier had to be replaced with a Sami Carrier that had been machined to accept the large diameter passenger side half shaft. With the Anvil set up I doubt the machining would be required :-/ MAybe somebody else will jump in here that knows for sure?  The good part it that your Kick ring gear will bolt directly to the sami carrier and the sami carrier fits right into the Kick/gv/xl-7 housings. I would suggest calling Hawk for all the "parts" you need to complete the install. Just tell Rick or one of his staff members that you have the anvil, 5.83's, and your doing a locker and steel housing. They will know exactly what you need ;)
Offline 90Stomper
  • 427
« Reply #4 on: June 16, 2005, 02:02:27 PM »
 ;D  cool ZP that clears things up! ;D  time to start looking for parts ;)
« Reply #5 on: June 16, 2005, 05:08:59 PM »
Just give me a shout if you have any questions.
Offline 90Stomper
  • 427
« Reply #6 on: June 17, 2005, 03:18:21 PM »
 ;Dthanks agian Zig, i will! ;)
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #7 on: June 19, 2005, 03:38:21 PM »
Ring gear will bolt up but should use a spacer to adjust back lash correctly (For the ring gear / kick ring gears is thinner then sammy) and a collar for the center pins (inside ring gear dia is larger / Sammy ring gear hold the pins in place)
Hawk has it all in stock and is great to help sort it out.
Offline 90Stomper
  • 427
« Reply #8 on: June 19, 2005, 04:13:30 PM »
would it be better/just as good/cheeper to just get the whole steel GV 3rd insted of the anvil?  does that even work?
i take it you both have/are happy with your anvils?  got lockers in them?  what kind? ;D
« Reply #9 on: June 19, 2005, 04:40:16 PM »
The nice thing about The Anvil is you just get to use your Right side axle on both sides.
But Mike H as an Article on how to convert your stock one over.
« Last Edit: June 20, 2005, 01:09:08 PM by trickker »
« Reply #10 on: June 19, 2005, 11:20:09 PM »
The center pin retaining ring is not needed with the 5.83's. Factory gears need it bit not the 5.83 aftermarket.
« Reply #11 on: June 19, 2005, 11:21:12 PM »
There is also an article about installing a steel Suzuki Axle in the front, hang on and I will see if I can find a link.
Offline 1bigtracker
  • 3409
« Reply #13 on: June 20, 2005, 04:34:34 AM »
But Mike H as an Article on how to convert your stock on over.
really?  link?
stu
« Reply #14 on: June 20, 2005, 12:43:17 PM »
really?  link?
stu
http://www.zukiworld.com/month_040103/feature_hagencvshaft.htm
http://www.zukiworld.com/month_120102/feature_hagan_frontendmod.htm
Check out the TECHNICAL ARCHIVE:
Lots of neat and interesting things are Afoot ;D
