kick rear upper V link options?
  • 12 Replies
  • 3251 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: May 16, 2007, 02:24:50 PM »
Hello all, I need to replace the upper heim joint on my kick with the Calmini 3" kit. Has anyone used a Jonny joint or another type of joint? I keep wearing out the heim joint and they are getting expensive. Also has anybody used different bushings in the rear trailing arms I also ruin them in short order.
    Kevin
   PS You should also use nylock nuts on the trailing arm bolts, I've lost a few :-X
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: kick rear upper V link options?
« Reply #1 on: May 16, 2007, 05:43:30 PM »
Something to consider:
Install a spacer block that would lower the upper end of the joint thus bringing the flex angle at that place back to stock.  Since it is up high, it won't hang on anything when offroading.
Hope this helps!
Ack
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: May 17, 2007, 11:53:15 AM »
I have the Calmini 3inch kit and have done Hagen's overrotation. the prob. is the heim gets worn out too fast.
« Reply #3 on: May 17, 2007, 12:20:11 PM »
Is it wearing because of dirt getting on it. Maybe a rubber boot packed with grease would help.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: May 17, 2007, 01:25:31 PM »
I'm thinking that A jonny joint will work better
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #5 on: May 17, 2007, 10:17:42 PM »
Are the Johnny Joints still on national back order?  It seems like a while ago there were lots of places that were saying they could not get them in stock.
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #6 on: May 20, 2007, 01:54:41 PM »
i just bought some last week.  stan
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #7 on: May 21, 2007, 04:07:36 PM »
That's good to know.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #8 on: October 17, 2007, 06:03:07 PM »
Anybody? ???
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #9 on: October 18, 2007, 07:46:20 AM »
I think rubicon express was making their own version of the johnny joint.  Give them a call and see if they have something that can be made to suit your calmini piece.
1993 4-door Sidekick
4.24:1 t-case
Offline chet
  • 556
  • Zuki time!
« Reply #10 on: October 18, 2007, 03:15:40 PM »
you need to measure between the mounting ears on the axle bracket to make sure a johnny joint or RE joint will fit in there. they are kinda wide. you can buy heims with grease fittings that may help.
How often are you replacing it and what price are you paying for the replacement? its just a 3/4x3/4 heim
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #11 on: October 18, 2007, 03:20:38 PM »
Yes!  Use the johnny joint.  Then you will need to post up pictures of teh install and let us know how it is working out.  If you repositioned the rear shocks I think that you could make that motha' flex a lot better.  Just guessing though.
As stated above the Johnny Joints are pretty wide, but with a little effort and fab I'm sure that it could be made to work.  Remember to post pictures.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #12 on: October 19, 2007, 11:36:20 AM »
Ya I know that I will have to widen the perch that bolts to the 3rd member, and refab a new v ilnk. I was just interrested to see what and if anybody had done this before. I am probabally going to use the Rubicon Express joint but mount it with the  ball sideways so the pin will be vertical. This way there will be less "side to side" pressure on the races in the joint. I hope it will last.
 Kevin
