sidekick brakes pulsating
  • 1932 Views
Offline greenmachine
  • 23
« on: May 18, 2007, 12:29:16 PM »
Hello all,
I have a 95 2 door with 4wd. All four wheels have new brakes and new front rotors. When I took the calipers off, I found that on both front wheels the lower slider pins on the caliper mounting brackets were frozen. I took them apart cleaned them and replaced them. The brakes were fine for a day or two. When they started acting up again, I figured that the pins must have been frozen again. But when I took the calipers off this time the sliders weren't frozen. Im not sure what the problem is. There is a ticking noise comming from one of the wheels, (I think) does that mean the there may be a bad bearing? Would a bad bearing make the brakes pulsate? Any help would be greatly appreciated. Thanks
Larry
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: sidekick brakes pulsating
« Reply #1 on: May 18, 2007, 01:38:46 PM »
The caliper itself may not be good.  You could try flushing the brake fluid also.
1993 4-door Sidekick
4.24:1 t-case
« Reply #2 on: May 18, 2007, 04:00:32 PM »
If the caliper was sticking at all, you could have possibly warped a brake rotor. That would account for the pulsating. Ticking could be a bearing, or a guide spring in the caliper out of place.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #3 on: May 18, 2007, 08:11:46 PM »
Inspect the rotor closely, too. The ticking could also be a cracked rotor...
  • 23
« Reply #4 on: May 23, 2007, 12:17:24 PM »
The rotors are brand new. it seems that they pulsate when the brakes get hot. Also it seems that the ticking only happens when i press the accelerator down. Any ideas what the ticking would be from?
