Front End Build Up
  • 19 Replies
  • 4900 Views
Offline Yoak
  • 577
Front End Build Up
« on: May 18, 2007, 03:12:52 PM »
I have read about several different options in terms of building up the IFS.
Here is my situation, just converted from 2WD -> 4WD.
Haven't even done anything and I already broke a CV.
So since I have some time and funds I want to build up the front end.
I have read about the Calmini anvil, and the various options that can be swapped into the car, but from what ive read, its not really needed as there are other cost effective options.
I am interested in swapping in stronger CVs and possibly a different 3rd member.
I am going to install arbs & re-gear the front when I do this..... any advice?
Re: Front End Build Up
« Reply #1 on: May 18, 2007, 03:57:52 PM »
Just out of curiosity, what were you doing when you broke that cv?
Offline Yoak
  • 577
« Reply #2 on: May 18, 2007, 04:04:34 PM »
Acually nothing major, which sucks cause at least then I could have a good story :)
« Reply #3 on: May 18, 2007, 04:13:15 PM »
That's weird, maybe just a bad or weak CV. I've been abusing mine ( ok, I am a freak about regular maintenance) for almost 2 years now, with lockers and 31's. I still have the aluminum housing in the front, and the old style cv splines. Still working great.  You sure you got everything squared away in the front end?
Offline Yoak
  • 577
« Reply #4 on: May 18, 2007, 08:20:18 PM »
Well i can post some pics,
Has a 3+3 Lift, and a new idler arm.
Driver side has the issue, so I figured if it is a weak link to go ahead and fix it now.
The piece is broken as it goes into the metal housing (does that make any sense)
« Reply #5 on: May 19, 2007, 03:33:37 AM »
What did you do to lower the front diff? With 3" of lift, your sure to put some serious stress on the cv's without lowering the diff.
Offline Yoak
  • 577
« Reply #6 on: May 19, 2007, 08:52:20 AM »
I used the calmini drop brackets
« Reply #7 on: May 19, 2007, 04:39:41 PM »
Maybe it was just time for that paticular cv to give up the ghost. It may have been ready to go before you did the lift, the lift just hastened it along.
Offline Yoak
  • 577
« Reply #8 on: May 19, 2007, 09:27:39 PM »
Possibly....
Ill post some pics....its kinda odd what it did....
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #9 on: May 20, 2007, 11:22:07 AM »
I kind of have to agree. I ran the calmini kit and the rockroad kit with the cast iron vitara center sections lockers etc etc with stock sidekick CV shafts on 31 and 32" tires and I was pretty tough on that truck and I never broke a CV. I always carried a spare cause they are cheap. I was getting them for like 25 or 30 bucks at a local pick a part yard.  Anyhow sounds odd. Were you turning excessively or something. Was it an OEM suzuki part? The aftermarket napa-like CV's are junk and I have seen them break before.  Now I have seen OEM CVs break a couple times, but under heavy load/turning...
By the way I have the cast iron center section and the toyota CV upgrade kit sitting on my garage floor. I would be happy to box it all up and ship to you!
front cast iron diff and houseing, machined carrier to accept CV, detroit locker, 5:12 gears, 550.00 (set up for a hagan widening set up)
toyota cv kit with cvs and hubs (one cv needs a new boot) 300.
let me know I am going to post this stuff up on ebay as soon as I get some motivation!
Hutch
speedball1981
« Reply #10 on: May 21, 2007, 08:40:10 AM »
i'd definetely go with the toyota upgrade kit,  the guys at apple valley,  (ultimate adventure, 2004)  were rocking 37 inch bf-g's with there if's with that toyota conversion, and we wheeled with them all day, and they wheeled hard.  i was definetely impressed.
Offline Yoak
  • 577
« Reply #11 on: May 21, 2007, 10:32:08 AM »
Sounds like a plan, toyota cvs then
Hutch I may be interested in your parts as well,
I have read that they can be used though without widening mod....on another forum is this correct?
« Reply #12 on: May 21, 2007, 12:53:47 PM »
Dang Hutch, I'd go for that diff and housing if you weren't on the other side of the country! Shipping would probably be another $200 to New Jersey!
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #13 on: May 21, 2007, 04:15:21 PM »
I know on the Calmini 2 inch with an Anvil does not need to be widened. I do not know about the 3 inch.
Mike
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #14 on: May 22, 2007, 04:31:11 PM »
nah it wouldn't be 200.. I'm guessing less than 100.00.. I will weigh that bad boy tonight..just out of curiosity.
hutch
