WANTED:struts
  • 1493 Views
Offline jeff1997
  • 1228
  • 27
WANTED:struts
« on: May 20, 2007, 08:09:54 PM »
I need a good set of used or new front struts for my 97 4dr. Sport Sidekick. It has abs so the struts are different from non-abs ones. If anyone has some or knows of a good brand and/or part #'s the help would be appreciated. Also if someone knows what the difference is between abs and non ones please do tell!!
3" Masterkit1 body lift
Custom strut spacers
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
Re: WANTED:struts
« Reply #1 on: May 24, 2007, 09:54:45 AM »
I work at a auto parts store and according to the specs the only thing that i can tell is the body length is different between the two. For the one with ABS has a body length of 12.25 and the one w/o ABS has a body length of 8.652. They both have the same mounts and travel but different body lengths. I cant tell for sure because i dont have a picture for the exact part number. The part # for the one with ABS is 71590 for the right and 71591 for the left. The part # for w/o ABS is 71932. These numbers are Monroe Sensa-trac Struts. They run around $70 each.
Offline jeff1997
  • 1228
  • 27
Re: WANTED:struts
« Reply #2 on: May 24, 2007, 08:32:05 PM »
Thanks 95tracker, that's the info I needed.
