Starting Problems
  • 5265 Views
00LudeSH00
Starting Problems
« on: May 21, 2007, 03:04:53 PM »
Hi guys, im new here and i have a problem with my 1990 Suzuki Samurai.  the problem is that it wont start.  I changed the plugs, wires, distributor and coil.  I talked to a mechanic and he said it could be the igniter.  I was wondering if you guys had any good ideas before i go throwing more money into it.  And if anyone knew of where i could find these parts online or anywhere other than a junkyard, ive  called junkyards around here and they dont have anything...Thanks a lot......
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Starting Problems
« Reply #1 on: May 21, 2007, 03:09:52 PM »
It might help if you told us what it does when you try to start it. Does the starter engage right? Does the engine turn over or not? If it turns over, does it just not fire? Can you smell fuel? Is the sammy EFI or carb?
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: May 21, 2007, 03:24:33 PM »
If you changed the distributor, but the starter turns the engine over, then the distributor is probably not set right, and so the timing is off so bad that it won't start.
How long since it started?  What did you do different for it to not start?
1993 4-door Sidekick
4.24:1 t-case
00LudeSH00
« Reply #3 on: May 21, 2007, 04:45:55 PM »
oh sorry, wasnt paying attention.  Its a 1990 samurai EFI.  I just went out one day tried to start it and it just turn over and thats all.  And i also wouldnt have any spark. but every now and then like once out of maybe 20 times it might start for about 5 seconds then shut off...and there is fuel too....
NEW_ZUKER
« Reply #4 on: May 21, 2007, 09:29:55 PM »
i know nothing about this stuff, but how about timming?????  are the injectors injecting????  fuel presure good???? compression in the pistons???
Offline W.O.T
  • 38
« Reply #5 on: May 21, 2007, 10:52:08 PM »
I have a 90 samurai also.  i had the same problem replaced everyting fuel pump to you name it.  i put it in the shop and it turned out to be a bad coil.  it was expensive but your problem sounds like what happened to me.  hope this helps!
00LudeSH00
« Reply #6 on: May 22, 2007, 04:00:13 PM »
ok...the mechanic said that i had power going from the ECM to the coil, then coil to the igniter, but after the igniter there was no power....but he wanted me to make sure cuase hes trying to keep the costs down for me....so i thought i would see what you guys thought....
