2 inch spacers. lop sided now
  • 9 Replies
  • 2527 Views
Offline bus_driver
  • 479
  • the voices tell me different things
« on: May 22, 2007, 06:18:20 PM »
ok this is a bit weird but i put the 2 inch spacers in the rear i hace crown vic shocks and the are also spaced about a 1/4 inch now the springs are at full length but not loose wich is what i wanted the problem is that all measurement from frame to groung show 1/4 inch difference left to right and on the tire to wheel well therer is 3/4 inch difference. now these spacers were in BFM truck b4 and they were fine I took the back end apart again and there is nothing binding or stuck and it rides great but looks so lopsided is there anything else ?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline bus_driver
  • 479
Re: 2 inch spacers. lop sided now
« Reply #1 on: May 22, 2007, 06:45:29 PM »
here are some pics of it
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline museboy07
  • 641
« Reply #2 on: May 22, 2007, 08:11:42 PM »
John1974 had the same problem and i think he solved it with a rear a arm spacer and longer shocks...
Offline bus_driver
  • 479
« Reply #3 on: May 22, 2007, 08:14:53 PM »
shocks are already longer  but i have not done the a- arm bracket yet i don't see how that would it at sitting height tho it is really strange to me i think i will take it apart ....the really strange part it that it was ok until i drove it and then it was lopsided ????
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #4 on: May 22, 2007, 08:38:28 PM »
Are you sure you have the lower spring ends in the pockets in the cups?
Offline fullsink18
  • 250
  • Wheel Me!
« Reply #5 on: May 23, 2007, 07:21:25 AM »
DIDO
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline bus_driver
  • 479
« Reply #6 on: May 23, 2007, 09:22:34 AM »
that was the first thing i checked for i even checked the upper bucket for rust and dirt but i did go out last night and drove it around and did some flexing and it is better now so i will drive it to work today and settle it in it is only like peter pointer finger difference now so i am ok with that.
92 2dr soft top
235/75/15
2 inch lift
custom mud
gieio
« Reply #7 on: May 23, 2007, 11:20:50 AM »
Did you make sure that the ends of each coil catch the notch in the coil spacer?  If one spring is not properly set into the spacer notch, this could result in one side being up to an 1" higher than the other side.  I know the Boondox spacers have the notch in them, on the downward facing side of the spacer, but I don't know if the other brands of spacers are the same?  Rich
Offline bus_driver
  • 479
« Reply #8 on: May 23, 2007, 11:38:26 AM »
these are home made and i did make sure the lowest part of the spacer is where the and of the coil would be if you look in the picture titled spacers the way i positioned it is spacer then ruber isolater then coil making sure that coild was in original part of rubber and coild end is on thinest part of the spacer it is not too bad right now mayber 1/4 inch out side to side so i am not too worried now but will drive it and see if it settles or something like that
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline bus_driver
  • 479
« Reply #9 on: May 24, 2007, 09:36:56 AM »
ok drove last night and all is well thank you for everyones help
92 2dr soft top
235/75/15
2 inch lift
custom mud
