91 sidekick power stearing on a samurai?
  • 1437 Views
Fasta76
« on: May 23, 2007, 09:54:39 PM »
Can i take the pump and power stearing box off a 91 sidekick and put it on a 86 samurai? im thinking of doing the 1.6 swap while im at it also!! If i want to run my carb, is there anything else i need besides the bellhouse adapter and electric fuel pump? I just use my distrib off my 1.3 right?
Offline mlovetripp0
  • 204
  • do more with less
Re: 91 sidekick power stearing on a samurai?
« Reply #1 on: May 23, 2007, 10:54:06 PM »
you will need the motor mounts ,to adjust for size of motor.
is there much difference between a 91 steering box and pump ,then a 96?
i just got done putting power steering on my 87 sammi.and it has a 16v 1.6 in it
and the stock location for the pump would not fit next to the steering box.we had to make a bracket using the old pump bracket and bolt it more towards the head of the motor.the steering box from a track/kick is much larger then the sammi's.but sooo worth it
« Last Edit: May 23, 2007, 10:56:40 PM by mlovetripp0 »
87 sammi
Fasta76
« Reply #2 on: May 24, 2007, 05:59:35 AM »
im not sure if there is much size difference??
