ome coils
  • 1900 Views
trackerbacker
ome coils
« on: May 25, 2007, 01:26:05 PM »
between hd ome front coils for a trackkick or a gv medium duty which will give a better lift and how much lift will it provide......inteding on using it for a tracker
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: ome coils
« Reply #1 on: May 28, 2007, 01:47:24 PM »
2-door or 4-door.  What bumper and winch will you have?
Weight makes all the difference.
1993 4-door Sidekick
4.24:1 t-case
trackerbacker
Re: ome coils
« Reply #2 on: May 28, 2007, 02:51:57 PM »
2 door and wont b addin a bumper but the winch will b mounted in the bed(converted back of tracker to a bed. so i want about a 2inch lift and dont know if i want hd tracker or md gv coils ..in a bit of a bind
Offline bzzr2
  • 1011
Re: ome coils
« Reply #3 on: May 28, 2007, 06:48:13 PM »
i believe the tracker coils are 30mm shorter than the gv coils from ome, check the arb site - you should find the info there.
09 taco reg cab short box 4x4
Offline crikeymike
  • 713
Re: ome coils
« Reply #4 on: May 28, 2007, 09:21:58 PM »
The GV coils will be too much on a 2-door with no additional front weight.
You could do the 4-door coils, light or heavy, but without any weight, it's hard to say how much lift you'll get.  Probably somewhere between 2 and 3".  3" of springs with no other changes isn't such a great idea.
Here's a link to the part options off ARB's site, but since you'll be mixing and matching, the heights will definitely be different.
http://arbusa.com/USA-Vehicle-Application-Guides/Suzuki-Sidekick-Tracker.pdf
4.24:1 t-case
