cj leaf springs in the front ?
  • 2078 Views
bryans 86
« on: May 28, 2007, 03:45:05 PM »
so i need some more lift and can get my hands on a set of 4 inch lift springs for a cj and i was wondering if i could put thses in my sammy with out to much modification i  already have yj springs in the rear need to get the front to match any info would greatly be appricatied
Re: cj leaf springs in the front ?
« Reply #1 on: May 28, 2007, 07:12:48 PM »
It can be done, but requires as much modification as your rear did. I'm pretty sure the stock CJ springs give about 2" of lift, so... might want to be careful with how much lift you're getting. May want to consider staying SPUA in order to not get too extreme of drive angles?
bryans 86
« Reply #2 on: May 28, 2007, 08:42:39 PM »
yea well i have toyota axles under neath and the rear yj springs were skyjacker 4 inch springs so it has some lift to it and i cant seem to find a away to match the front up to the same ride height as the rear i was thinking a 5 inch lift shackle jk jk
« Reply #3 on: May 29, 2007, 09:52:00 AM »
There's CJ kits out there, or you could build your own. Lift shackles - hahaha. Speaking of shackles, you might want to reverse the ones in front while you're at it.
Offline Amilla
  • 1076
« Reply #4 on: May 31, 2007, 11:44:35 AM »
Toyota front drivelines solve high angle problems pretty well.
Amilla
bryans 86
« Reply #5 on: June 12, 2007, 08:30:02 AM »
i already have a 5 inch lift shackle ( its sitting in my garage dont worry im not driving it ) and its about where i want it
