camber bolts
  • 12 Replies
  • 3260 Views
Offline sidekick 4x4
  • 97
  • sidekick
camber bolts
« on: May 29, 2007, 07:16:15 PM »
i bought camber bolts of boondox and i put them on and adjusted them the best i could and ive adjusted them many times but i still cant make my tires streight there like this \  / and all i have is  1.5 coil spacers strut extenders and i did the strut flip mount so if anyone has any ideas that would help
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
Offline locjaw
  • 2045
  • 22
Re: camber bolts
« Reply #1 on: May 29, 2007, 07:37:29 PM »
this video explains a lot.....
http://www.iapdirect.com/pictures/EZCam1.wmv
if that dont work try it in the bottom hole, or both!
winners never quit ;D
jason
  • 97
  • sidekick
Re: camber bolts
« Reply #2 on: May 29, 2007, 07:39:10 PM »
ive watched that video befor and ive tired the bottom hole and that makes it worse and both doesnt make it any better
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: camber bolts
« Reply #3 on: May 29, 2007, 11:18:48 PM »
are you driving it after you adjust it?  The \  / will settle after you drive it.  This shouldn't be a big deal with the camber bolts installed in the top hole, unless there was something wrong with the bolts themselves.
1993 4-door Sidekick
4.24:1 t-case
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: camber bolts
« Reply #4 on: May 30, 2007, 05:17:49 AM »
You're running BOTH strut extensions AND a strut mount flip? That's where your camber issue is coming from. Most likely the mount flip is doing the most to hurt the camber. You either need to reverse the mount flip back to stock and just stick with the strut extensions, or you need to fab up a way to move your flipped mounts further inward towards the engine...
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: camber bolts
« Reply #5 on: May 30, 2007, 11:17:38 AM »
ya mine was still off after my 3 inch lift coils, and camber bolts, I drove it about 100 miles and poof all good...
Trackin92
Re: camber bolts
« Reply #6 on: May 30, 2007, 12:15:17 PM »
So I am gonna be buying the Calmini 6" suspension and body lift kit here soon and does that kit have any problems with camber?
  • 97
  • sidekick
Re: camber bolts
« Reply #7 on: May 30, 2007, 08:24:12 PM »
so you guys think my camber is off so bad bc i have strut extenders and the strut flip mount
Offline Uncivilized
  • 1469
    • Car Domain
Re: camber bolts
« Reply #8 on: May 30, 2007, 08:49:46 PM »
Might be alignment:
Take your rig to some pavement, check your camber by eye after driving forwards and backwards... If your toe is out much(in or out), it can effect camber. The tires can push the suspension up, or pull it down. mikerpm4x4 could explain this better than me, he did something like this purposly by flipping his outer tie rods.
  • 97
  • sidekick
Re: camber bolts
« Reply #9 on: May 31, 2007, 06:05:31 AM »
yea its weird when i drive my camber is really bad there litteraly like this \ / but then when i park there almost perfect, there only off by a little bit when i park
gieio
Re: camber bolts
« Reply #10 on: May 31, 2007, 11:41:42 AM »
The Calmini kit will give you serious camber issues. You will definitely want to switch to rims with 2 to 2.5" backspacing, and will also need camber bolts.  I drove mine for about 50 miles, with no change in the extreme camber.  I ended up sending it back, and going with a Boondox lift. Be forewarned, the front springs on these kits are extremely stiff, I think they were made to handle the weight of a Dodge Cummins engine or something very heavy. Calmini told me they were designed that way for the extra weight of a winch, but with my 210 lbs of weight on the front bumper, bouncing up and down, I couldn't get the front end to compress more than about a 1/2".  You might consider an Old Man Emu or Boondox suspension, because at least with these you can buy parts, or replacement parts, individually, and the ride will be much better.  Rich
Re: camber bolts
« Reply #11 on: May 31, 2007, 06:14:42 PM »
Definitely check your alignment. If it changes that much, something is out of whack. Odds are with that many changes your toe and camber both need correction. Can't do one without the other.
Trackin92
Re: camber bolts
« Reply #12 on: May 31, 2007, 11:26:29 PM »
i already have the wheels with backspacing. Just cant decide if I want to keep them though lol.
