sammy transfer case question
  • 2035 Views
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« on: May 29, 2007, 07:54:28 PM »
If a sammy transfer case pops out of gear, will a rebuild solve this or are there  parts that you need to buy in addition to the standard rebuild kit to solve that problem?
-Adam
Re: sammy transfer case question
« Reply #1 on: May 29, 2007, 08:39:59 PM »
Watch the shifter and give it some gas and then let off while driving and see if it moves forward and back, if so you might want to look for a new one.
Offline ROSS
  • 1412
« Reply #2 on: May 29, 2007, 08:49:23 PM »
does it have a body lift???  broken t-case mount???  maybe hitting the floor???
« Reply #3 on: May 30, 2007, 09:05:27 AM »
Usually it just needs a new plastic bushing for the shifter sheet doesn't it?
Offline daddyizzle
  • 728
« Reply #4 on: May 30, 2007, 09:41:21 AM »
Not mine but I had a previous samurai that would jump out of 4 wheel drive but not out of 2 wheel drive. This is actually one that a guy says needs rebuilt and needs what ever is broke fixed since it was jumping out of gear. I think his words were that you would need to replace the broken part that makes it jump out of gear. I would think it would just be the bushing if the mounts were all good myself.
-Adam
« Reply #5 on: May 30, 2007, 11:00:07 PM »
There is a fix for the four wheel drive part poping out, it is about 100.00 or you can use a washer behind the bearing and turn the collar over.It's the part behind the front out put.
