Front Crank Seal Replacement
  • 10 Replies
  • 4444 Views
Offline jerryp58
  • 449
« on: December 08, 2004, 04:01:43 AM »
Do you have to remove the oil pump to change the front crank seal?
Jerry
Offline mbmarkyb
  • 461
    • UK Vitara
Re: Front Crank Seal Replacement
« Reply #1 on: December 08, 2004, 05:02:01 AM »
i found a i had to use a nut gun to remove the pully but left the oilpump in place
Markyb (UK)
UK Vitara JLX SE
Offline jerryp58
  • 449
« Reply #2 on: December 08, 2004, 12:26:32 PM »
Wild, it looks like your post didn't make it... will mine I wonder  ???
Well, mine made it.
mbmarkyb, did you remove the crank oil seal with the oil pump in place, or just the gear?
« Last Edit: December 08, 2004, 12:28:40 PM by jerryp58 »
Jerry
Offline bioniconion
  • 268
« Reply #3 on: December 08, 2004, 12:56:40 PM »
lol a "nut gun" ouch  ;)
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #4 on: December 09, 2004, 12:31:15 AM »
yeah didnt remove the oil pump you can get to the seal with out it just press it in nice and straight,
nut gun = air gun the thing the tyre changer uses lol :-) that was to loosen the pully bolt
Markyb (UK)
UK Vitara JLX SE
Offline bioniconion
  • 268
« Reply #5 on: December 09, 2004, 01:26:48 AM »
ahhhh! ok i get ya now
Offline jerryp58
  • 449
« Reply #6 on: December 09, 2004, 02:38:49 AM »
COOL!
I hope I'm that lucky.  Pulling that oil pump sounds like a major PITB.
Jerry
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #7 on: December 09, 2004, 03:27:53 AM »
i read it again and yeah i think some of my text was missing ,
oil pump isnt to bad , just have to find all the bolts the pully was the worst part as you cant clamp it off very easy as it breaks thats where the old nut gun cam into it
Markyb (UK)
UK Vitara JLX SE
Offline jerryp58
  • 449
« Reply #8 on: December 09, 2004, 08:33:36 AM »
I think the manual shows a tool that actually sits against a flywheel tooth and makes the flywheel immobile.  I'm assuming they did that to make getting the bolt off easier.  I have an impact wrench, so hopefully, that'll do the trick.
Jerry
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #9 on: December 09, 2004, 11:13:25 PM »
when you say fly wheel are you doing the rear crank seal or the front one near the raditor ?
i did have to remove my raditor to get teh impact gun in there , :-(
Markyb (UK)
UK Vitara JLX SE
Offline jerryp58
  • 449
« Reply #10 on: December 10, 2004, 03:26:21 AM »
The front seal.  But if you immobilize the flywheel, the crank (and the nut) can't move on you.
Jerry
