twisted splines ?????
  • 2198 Views
Offline honduro
  • 18
« on: May 31, 2007, 02:57:49 AM »
Trying to disasemble  my rear to install lockers in a 1989 sidekick . I've got the four flange nuts off the rear , the backing plate loose, and cannot get the axle to pull out of the rear .    Is there something else that im missing ? Our alldata at work shows nothing else as in a circlip that holds the axle in. Just wondering if i may have twisted splines ,  by the way either side will come off . Thanks Dennis
Re: twisted splines ?????
« Reply #1 on: May 31, 2007, 03:44:01 AM »
I had to use a slide hammer attached to the end of the axle to get mine out. That bearing is a tight fit in the housing.
« Reply #2 on: May 31, 2007, 05:58:38 AM »
Yea, what he said  ;) I spent A LOT of time trying to get my axle out before I drove to the local parts house and rented a slide hammer. After a couple of quick tugs it poped right out. I ended up buying one after a few snapped axle shafts.
Offline ROSS
  • 1412
« Reply #3 on: May 31, 2007, 06:05:37 AM »
I carry a slide hammer in my tool box. that's what it takes to get them out. I also use it to knock them back in.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #4 on: May 31, 2007, 11:58:09 AM »
Big hammer, I got a huge hammer that I hammer on the back... my 87 sammy was hard to get them out the first time, my tracker was alot easier... keep at it!
« Reply #5 on: May 31, 2007, 10:25:48 PM »
You can use a high lift jack as a slide hammer also.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #6 on: June 02, 2007, 06:14:56 PM »
flip the brake drum over and put the nuts back on a couple turns. Use the drum like a slide hammer. They will come out..
Offline calabrias1962
  • 102
« Reply #7 on: June 02, 2007, 09:53:32 PM »
Thats an excellent tip thanks :)
88 Samurai, SPOA,Dual sami Transfer Cases, 513' mini spool rear, Lockrite front 31 10.50 MT's
