water cooled valve cover breather??????
  • 2193 Views
eschneider
« on: June 01, 2007, 02:03:50 AM »
wish I had a picture.
'92 8v tracker 1.6L
whilst doing a head gasket, I noticed a weird connector between the valve cover breather pipe and the aluminum air plenum.  It had water lines going to it.
Uhhhh - Houston, WTF, over?
Re: water cooled valve cover breather??????
« Reply #1 on: June 02, 2007, 11:08:44 AM »
probably and air intake pre heater hose for cold days. my 16 vavle has that and an i.a.c. heater also.
eschneider
« Reply #2 on: June 03, 2007, 01:32:09 AM »
No, its not on the air intake - it's on the 1/2-inch rubber line from the valve cover that vents crankcase fumes to the intake.
It's a metal ring about the size of a quarter, with a 5/16 coolant supply and a 5/16 coolant return line.
I've never seen anything like it.  I can't imagine why crankcase vapors would need to be temperature-regulated, or that this small donut would actually do much as vapors passed through it.
Anybody?
« Reply #3 on: June 03, 2007, 10:12:03 AM »
Anybody?
Sounds like it could be the PC Valve, got a pic?
eschneider
« Reply #4 on: June 04, 2007, 12:22:55 AM »
[/quote]
[/quote]
No pic.  Car is 200 miles away at the moment....
Definitely not a PCV valve.  It's straight through - no vlaves or restrictions whatsoever.  The vented fumes pass straight through it.....
