Stock Tracker Trans/Tcase
  • 2339 Views
Offline explosivo
  • 3157
« on: December 08, 2004, 10:06:14 PM »
So, now that the Tracker is sitting out back, I may be able to save up some dough for the 'yota axle swap, but I'm wondering now how the stock 5spd and t-case are going to hold up with Toyota axles and 35/37's. Will I be set if I get one of the centerforce clutches (I've actually managed to make a fresh clutch last for the past year doing mostly daily driving with the 33x13.50 LTBs), or are the new tires going to be too much for the tranny?
Also, what gearing should I look into for the axles running 35/37" tires with a Tracker trans and t-case and Samurai t-case? Would 5.39's be too low in that setup, or just about right?
omghi2.us[/url]
Re: Stock Tracker Trans/Tcase
« Reply #1 on: December 08, 2004, 10:33:30 PM »
I think it would hold up fine. I have beat the hell out of mine with 33's for years, and Mike is running stock Trans and 4:1 Kick case with his 35" Krawlers.
So your doing a dual t-case set up? If you were doing single I would think a 4:1 and 5.83's would work. If I remember correctly, I think Toy axles gear down into the 6.?? range. I know you could pull 37's with that kind of gearing and a 4:1.
« Last Edit: December 08, 2004, 10:34:04 PM by Zukipilot »
Offline 1bigtracker
  • 3409
« Reply #2 on: December 09, 2004, 03:33:41 AM »
are you building a rock crawler or a mud truck?  no time to talk now, be back later to give input.
stu
Offline Ian
  • 50
    • Island Rock Crawlers
« Reply #3 on: December 09, 2004, 03:45:08 AM »
The lowest Toy R+Ps are 5.29 and 5.71.
Offline explosivo
  • 3157
« Reply #4 on: December 09, 2004, 11:46:30 AM »
stu
Trail truck, more into the muddy stuff, though. Sammy t-case idea is for getting rid of the slip yokes with the straight axles and to give a little bit of gear reduction.
omghi2.us[/url]
Offline explosivo
  • 3157
« Reply #5 on: December 09, 2004, 11:46:55 AM »
Brain fart there, I meant 5.29's, not 5.39's
omghi2.us[/url]
