Lockers??
  • 2667 Views
Fasta76
Lockers??
« on: June 02, 2007, 05:57:27 PM »
When i look up lockers for the samurai. It asks with or with out couplers??? What is the difference? And if i went from 3.73 to 5.13 what % reduction would i get?
Offline Armour
  • 360
Re: Lockers??
« Reply #1 on: June 02, 2007, 10:20:44 PM »
I am not sure about the reduction but the locker with couplers. The couplers replace the side gears. Apparently you don't really need the coupler usless your side gears are heavily worn. I also hear that the unit without couplers is less noisy. Just a matter of which you prefer.
Fasta76
Re: Lockers??
« Reply #2 on: June 02, 2007, 10:42:06 PM »
Thanks for the input!! Would 5.13 be overkill for 31" tires. Im thinking of going 31-12.5-15 cause most guys say 33" are tough on stuff!!
Offline blasterfan
  • 54
  • SHEAAAAA
Re: Lockers??
« Reply #3 on: June 02, 2007, 10:47:47 PM »
not sure on the locker question, i just welded my rear end up..
iam running 5:13 gears with 31x11.5 mud tires, it seems good to be. i ran some fairly hardcore trails today with it, and it did really well... tons of bottom end power ( compaired to 3.91 gears i had before) to get the tires spinning
85 tin top: spoa, weber, thourly, mud kings, no rust, shackels bumpers
88.5 soft top: spoa, lift springs, shackels, 1.6L, hybrid real axle, yota drivshafts, 5:13 gears, bumpers, winch, rear rad, 5 points and buckets, ltbs, lockers, custom exhaust, some trail scars and alot of army green paint
trackerhn
Re: Lockers??
« Reply #4 on: June 04, 2007, 03:23:04 AM »
Hi,
I am also thinking of putting a Calmini rear locker into my 2x4 1992 Tracker as I am not able to upgrade it to 4x4 now (can't find parts).
Do you think this upgrade will improve the offroad capability of my Tracker?
Thanks
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Lockers??
« Reply #5 on: June 04, 2007, 07:44:07 AM »
Well 4.62's give you about a 20% reduction.  reason I know this is I tossed 4.62's into my 87 sammy sitting on 31x10.5's and that reduction was perfect for them on highway.  Alittle to much actually. 5.12's would be way to much in a sammy on 31's
g-man
Re: Lockers??
« Reply #6 on: June 04, 2007, 08:21:50 PM »
Hi,
Thanks
Update your profile to show location, plenty of people have the parts you need to do the conversion to four wheel drive.
trackerhn
Re: Lockers??
« Reply #7 on: June 05, 2007, 09:53:50 PM »
I live in Hanoi, Vietnam
(there are only few trackers in the city !!!!), parts is not easy to find .
so even if I can find parts (for 4x4 conversion) outside the country, shipping cost and taxes will be a lot ?!
