31-10.5-15 or 31-12.50-15??
  • 25 Replies
  • 5539 Views
Fasta76
« on: June 02, 2007, 10:45:43 PM »
HEy guys i was thinking of putting 31-12.50-15 tsl swampers on insted of 33-12.50-15. <ost seem to say that 33 are a little to big for stock diffs! But is that because they are to wide or to tall? Would a 33-10.50-15 be better??? Would 5.13 gears be better for 31 or 33" tires?
Fasta76
Re: 31-10.5-15 or 31-12.50-15??
« Reply #1 on: June 03, 2007, 07:19:14 AM »
someone must have some input here!!
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: June 03, 2007, 08:31:41 AM »
on what rig, tracker? Sammy? sidekick?... t-case gears? stock?
5.12's usually are whats rated for 33's  I currently run 31x10.5's with my 5.12's in a 3 speed auto tracker....
depending on the wheeling you do you can get away with 33's on stock axles, couple people I have known for years on there sammys have done so.  But of course its more stress, and as I send if you do alot of rough wheeling you could run into a broken axle shaft or two.
Fasta76
« Reply #3 on: June 03, 2007, 09:18:36 AM »
86 sammy,1.6 8 valve swap,lockright locker in the rear,stock t-case for now. It would be nice to have 33" for the extra height. Do guys find a huge benefit from going from 31" to 33" tires?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: June 03, 2007, 09:32:03 AM »
It really depends on your driving style. I would go 33s as wide as possible, but thats me. :-\ Is it also going to be street drivin? Stock gears? Locked? Do you have a heavy foot or are you more of a crawler? Need more info.
Mike
Fasta76
« Reply #5 on: June 03, 2007, 09:41:28 AM »
1.6 8 valve , 5.13 gears, stock t-case. I drive it somtimes to work. About 30km round trip. Im looking at TSL, TSL-SX, TSL Radials.. I would like boggers but they would for sure beak stuff!!
Offline fieroboy_gt
  • 59
  • whoo
« Reply #6 on: June 03, 2007, 12:02:52 PM »
I'v always ran 33 on my sammi, transfer case stock no lockers an I beat the hell out of it an every year I replace a rear end I run a thin tire 33x10,50x15 to try an put less wear on the vehichle an there better in mudd. I upgraded from 31 like 3 years ago an found the 33 more tippy. so I bout 2 inch spacers an longer whell studds an it kinda evens it out. but i have rolled it on average of 1 a year with or with out the 33's so go figure
Cars an Guitars an my band Insurrection
« Reply #7 on: June 03, 2007, 01:29:27 PM »
Diff gears are always a good idea when going that big. The rest is personal prefrence...
I'm not a fan of going larger than 31" on a Sami, as things start breaking a lot more often. Frankly, I'm a minimalist. I like to keep things simple - I don't like broken things. Some people don't care if they break things, so they just keep going bigger and bigger....
Fasta76
« Reply #8 on: June 03, 2007, 02:23:38 PM »
Thanks for the input guys!! Would 5.13 be way to much gear for 31" tires
copperfever
« Reply #9 on: June 03, 2007, 03:36:23 PM »
I ran 31x11.50's on my '88 with stock gears. It was a little sluggish on the highway, but did great offroad.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #10 on: June 03, 2007, 05:46:53 PM »
It will be wound up with 31s but zuks kinda like that. If you go to a 33 get a tire that is less agressive to keep the axles alive.
Mike
« Last Edit: June 03, 2007, 05:58:19 PM by Mikerpm4x4 »
Fasta76
« Reply #11 on: June 03, 2007, 09:36:41 PM »
would most of you guys run a 33/10.50/15 over a 31/12.50/15?
Offline bzzr2
  • 1011
« Reply #12 on: June 04, 2007, 07:16:37 AM »
i think rotational mass is a factor here for durability.  how much does a 31x12.5 weigh when compared to a 33x10.5?
09 taco reg cab short box 4x4
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #13 on: June 04, 2007, 02:43:49 PM »
Depends on the tire. 31 inch Swamper ssr vs a 33 125 BFG mud terrain, the swamper is at least 25% heavier.
Mike
Offline Mac500r
  • 69
  • Alot more to do!
« Reply #14 on: June 04, 2007, 10:22:21 PM »
I recommend a  31-32 x10.50-15 tire unless you plan on changing axles.
I would go with a radial mud tire that is not quite as aggressive.Less breakage and longer lasting on hard surface with adequate traction.
Just my 2 cents worth:-)
1996 Tracker 2door soft top.2.5" exhaust,High flow Cat,Home Built Muffler,2" Ironman springs and rear shocks,OME Struts/Mounts Flipped,K&N Filter Modded Air Box,Ported MAS Sensor, spring spacers,A-arm drop brackets,strut spacers.5.5" total susp.lift.33x10.5-15 BFG MT.Home built Bumper,2.5" B/L.
