Need to level out...
  • 1734 Views
Offline museboy07
  • 641
« on: June 03, 2007, 07:48:04 PM »
I just installed a set of Jeffs 2in coil spacers and now the front sits a little higher.  Bout an inch i think.  If I were to swap in a set of 4door coils in the back (mines a 2door) you think that would level me out?  They supposedly give about an inch of lift.  If so then ill fab up a rear a arm spacer and some longer shocks (currently running crown vics)  Any input?
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Need to level out...
« Reply #1 on: June 03, 2007, 08:27:26 PM »
You're right on the money, 4 door coils will level you out nice. Flex it out before you buy more shocks but the A-arm spacer is a good idea
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline museboy07
  • 641
« Reply #2 on: June 03, 2007, 08:35:51 PM »
thanks biker just wanted to clear that up.  But what do you mean flex it out before more shocks?
Offline biker
  • 730
« Reply #3 on: June 03, 2007, 08:42:54 PM »
flex the susp to maximum to see if your springs start to come loose. Probably will flex better with the spacer in there
99 Vitara 2wd
10 Gr Vitara
Offline museboy07
  • 641
« Reply #4 on: June 03, 2007, 08:50:14 PM »
ya im thinkin it will.  Should i use a 3 in spacer for it since i would have a 3in sus. lift?
Offline biker
  • 730
« Reply #5 on: June 03, 2007, 08:52:53 PM »
I would match it to the lift for best effects, Just remember to make it really strong as it takes a lot of abuse
99 Vitara 2wd
10 Gr Vitara
