power stearing??
  • 1420 Views
Fasta76
power stearing??
« on: June 05, 2007, 06:10:05 AM »
What is a good power stearing swap to do in a 86 sammy? Im putting in a 1.6. I was thinking from a trackick but was unsure of the years they came with power stearing? Would thay be strong enough for 33" tires?
Re: power stearing??
« Reply #1 on: June 05, 2007, 11:50:05 AM »
mine is from a 1994 four door,I use both the steering gear and the pump, I used to have the ac compressor on it also but it made the belt slip so I removed it,you will need a large trany cooler on it and have it in front of your fan or give it it's own fan if you plan on rock crawling to keep it cool so it won't fade on you, mine does in the snow but I have a real small cooler on mine, the larger one is sitting on my shelf,LOL yes on the 33'S.
