drive shaft length?
  • 1430 Views
Offline bandit86
  • 1641
  • elv8rguy
drive shaft length?
« on: June 05, 2007, 07:28:08 PM »
I want to lower the front subframe 4 inches, which I can do with the normal front driveshaft, but I also want to move it more forward, needing longer shafts.  How much longer is the rear shaft then the front on a 2 door 95?  I know if you use the rear shaft off a 4 door you can move it down 6 and 9 forward but thats too much for what I need
badhabits
Re: drive shaft length?
« Reply #1 on: June 05, 2007, 08:04:25 PM »
The differance between the 2dr MT and the 4dr AT front driveshaft is four and five eights inches. I know this for a fact, can remeasure if you like.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: June 05, 2007, 08:14:58 PM »
automatic shaft is longer?  Is the rear longer too?
