plz help.... got the lift instaled but driveshaft spacer left out...
  • 14 Replies
  • 3334 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
hey i got the lift put in and the shop doing it said that the the drive shaft spacer would cause binding so they left it out  has anyone else experienced this wut should i dooooo????
 its the 3" suspen. by clamini on a 94 sidekick
plz  respond
copperfever
Re: plz help.... got the lift instaled but driveshaft spacer left out...
« Reply #1 on: June 07, 2007, 09:21:14 AM »
Don't listen to them, you really do need it.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #2 on: June 07, 2007, 10:36:17 AM »
why they were pounding it in with a hammer, was yours this hard, i really dont wana pull a drive shaft,  so i should go have them finish the job??
« Reply #3 on: June 07, 2007, 11:22:33 AM »
The drive shaft is only 4 bolts. (14mm if I remember correctly). It shouldn't take 30 minutes if you have never attempted it before. But if you dont want to get dirty, they should of installed it with the lift. So they should do it now.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #4 on: June 07, 2007, 01:00:28 PM »
hey if they said it waould cause binding, because of how tight it was should i still do it??? calmini said im the only rig that dosent have it in.
reply soon thanks
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #5 on: June 07, 2007, 02:27:37 PM »
The only binding that can be at that end of the driveshaft is if the yoke binds on itself.  This shouldn't happen unless you've got too much lift.
I had this problem on a sami before, on the front end, and it was because my pinion angle wasn't right after a spring over.
1993 4-door Sidekick
4.24:1 t-case
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #6 on: June 07, 2007, 06:36:11 PM »
it might be the wrong size spacer, I got some for my samurai that were to thick and cause things to bind up on uptravel.  I would go under there see how much your shaft is out, and get a spacer close to that size, if yours is that size, then toss it in and no worries...
Offline SKAsammy
  • 79
  • 1991 samurai
« Reply #7 on: June 07, 2007, 07:14:55 PM »
are you trying to put it at the top of the driveshaft or the bottom?
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #8 on: June 07, 2007, 08:40:41 PM »
alright, i stoped by cascade offroad again and they called calmini right infront of me.    the spacer wont fit right now its suppose to fit at the bottom of my back drive shaft, calmini said they have never seen this, they told me to keep flexin the setup and let the coils and shocks settle, come back then see if the spacer is needed, if not toss it you wont need it.  i flexed the kicker out to day and looked at the drive shaft and still had plenty shaft in.  ill keep updated on if it works or if i break a drive shaft, lets hope its number 1.
Offline crikeymike
  • 713
« Reply #9 on: June 07, 2007, 09:54:48 PM »
Now that i realize you're local, you've gotta bring it by so i can check it out.  Believe it or not, i've never seen the calmini lift in person.
4.24:1 t-case
Offline tipover
  • 422
« Reply #10 on: June 08, 2007, 09:01:06 AM »
how thick is it?
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline DaddyDave
  • 204
  • Indeed
« Reply #11 on: June 08, 2007, 09:36:18 AM »
It's a 3/4" spacer.  The shop likely doesn't have the upper V-bar dialed in.  Ask them for the angle measurements coming off of the pinion flange and the t-case.  They should be the same. You will likely find that they are not.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #12 on: June 08, 2007, 10:06:19 AM »
i dont know what they are doin, im not to good with specs and stuff on the sidekick.  i know if it breaks theyll fix it.   but ya ill try to get some pics of the drive shaft unflexed and flexed.  this week end.  how long did you guys go untul you did the alignment, calmini said not to till the coils settle because it will be a waste of money.  any info on this???
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #13 on: June 08, 2007, 11:18:46 AM »
My coils are still "settling"...  Since 2003.  I think I need new coils, or coil spacers at this point.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #14 on: June 08, 2007, 12:30:49 PM »
so when should i get my allignment then two weeks??? if i still flex daily
