Transfercase arms
  • 1614 Views
Offline calabrias1962
  • 102
Transfercase arms
« on: June 08, 2007, 08:29:11 PM »
Does anyone have any pic's of how they reinforced their long and short
arms?
Thanks
88 Samurai, SPOA,Dual sami Transfer Cases, 513' mini spool rear, Lockrite front 31 10.50 MT's
Re: Transfercase arms
« Reply #1 on: June 09, 2007, 02:18:57 AM »
No picture, but I just welded a piece of angle iron on the inside of the long arm.  Haven't had any problems with it bending.
  • 102
« Reply #2 on: June 09, 2007, 05:01:27 AM »
Did you lay it in the same as the arm or did you put it so it made it boxed?
Hope this makes sence.
Thanks
« Reply #3 on: June 09, 2007, 10:41:55 PM »
boxed would be better,on the small arm get some round stock and bend it around the corners and weld it good, and the long arm on the frame clean the inside of the long arm and weld it to the frame, it only comes with the out side welded and will tear off of the frame if you wheel it.
