Losing my virginity
  • 2174 Views
Offline Armour
  • 360
Losing my virginity
« on: June 09, 2007, 08:59:52 AM »
 Had the rig out for it's maiden voyage. Just wanted to cross this dam little creek. It had other ideas.
Re: Losing my virginity
« Reply #1 on: June 09, 2007, 10:23:11 AM »
Momentum youg grasshoppa (and alot of skinny pedal)  ;D
Nice Stuck. So did you try it again to see if you could make it?
Offline Armour
  • 360
« Reply #2 on: June 09, 2007, 01:22:39 PM »
I need to get  gears for the transfer case. Needs more torque to get those 33" spinning. Or a V6. Gears are alittle cheaper right now. So no I didn't try it again at that point. My buddy got his Vitara stuck alittle farther down and I tried to pull him from the back with no success. So I tried to cross a safer spot but that didn't happen. The mud was so thick, that was the only problem. I was moving back and forth fine just couldn't get over the foot and a half lip on each side. I'll get it next time..... I will be back!!!
