Snorkle questions
  • 32 Replies
  • 8526 Views
0 Members and 14 Guests are viewing this topic.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Snorkle questions
« on: December 01, 2004, 05:18:41 AM »
Well, the other day while out wheeling I came across a rather large mud/water crossing and got some in my air box. I am looking at the type of snorkle that could also act as a cold air/ ram effect type. Has any one used one and what are pros and cons. I would like to buy one but I dont really like the hokey looking home made jobs :-/
thanks in advance,
 Kevin
94 purple/green splash tracker w/ calmini 3' heavly modified lift 32 11.5 r15 bfg m/t's  & custom air induction and header w/ 2"exh. no cat lockrite rear 2" B/L and a heavy right foot and now 583s steel up front and locked.
2002 GV 2.5l 4.5 ZN lift locked on 31's
Offline paps133
  • 166
  • make your own road..
Re: Snorkle questions
« Reply #1 on: December 01, 2004, 05:30:56 AM »
tHE ONLY ONES THAT I KNOW ABOUT ARE THE SAFARI SNORKEL. BUT THEY DON'T ACT AS A RAM AIR UNLESS YOUR DRIVING FAST. WHAT I DID WAS I ADDED A TORNADO FAN.  I COULDN'T TELL IF THE FAN DOESN'T ANY THING BECAUSE I DID ALL MY MODS AT THE SAME TIME. iF YOU NEED PICTURES, YOU KNOW HOW TO FIND ME, PIERRE
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: December 01, 2004, 06:04:46 AM »
Ya, the safari snorkle. Do you use your stock
air box? If so I'll need to get one of those too.
Offline Cwkick
  • 888
« Reply #3 on: December 01, 2004, 07:32:29 AM »
Yes you use the stock air box.  You have to drill a large hole in your fender to install it so be aware of that.
I am thinking of getting one.  Not because I go through much deep water, but because I think they look cool.  :D
Cwkick
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: December 01, 2004, 07:45:35 AM »
I think that with it getting cold air the preformance will increase. Is safari the only one they make?
    thanks
    Kevin
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: December 01, 2004, 07:45:48 AM »
I run a Safari snorkel on mine. Yes they work well in keeping the water out, already given it a good work out with multiple hood deep river crossings. You will get a small amount of induction noise though I don't notice it with the windows up. It will give you cooler air but I don't feel that it has improved performance in any real way. For really dusty conditions there are additional foam pre-filters that can be installed in the the top. The install was easy enough.
Offline wolf66
  • 193
« Reply #6 on: December 01, 2004, 09:50:04 AM »
I don't think the homemade ones have to look bad, you just have to use black ABS instead of PVC.
Mine cost me around $50 and thats including the $20 to buy the 2"3/4" hole saw drill bit to make the hole.
The Safari ones will be over $300 with shipping so to me it would have to look 6 times better....
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline explosivo
  • 3157
« Reply #7 on: December 01, 2004, 11:30:23 AM »
I'll take the less asthetically pleasing homemade version over a $200 snorkel ;D
omghi2.us[/url]
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #8 on: December 01, 2004, 08:10:52 PM »
anyone got any more snorkel pics? (homemade etc...)
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #9 on: December 01, 2004, 08:25:08 PM »
Explosivo, I was wondering about the filter set-up like yours. Doesn't it get wet and make the carb run like it's on the choke ( remember my bikes with K&N's running bad in the rain due to wet filters ).
I asked around for the Cyclone filtercaps like the Landrover Defender run and they are about 40 Euro's ( so just over $ 40,-  ) so that might be a good alternative. I'm going to have the pipe running from the filterbox to the windowsill bent by someone that makes exhausts.  Any thought on pipe diameter ? Air-entrance in the original filterbox is very small, so 2 "pipe should suffice ?
( stock 1300, stock carbed 88 Samuari )
Pics will follow of course ;)
« Last Edit: December 01, 2004, 08:26:19 PM by nitromax »
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #10 on: December 01, 2004, 08:35:48 PM »
Jip, I think 2" should be enough. I have about 3" on my Vitara (home made too  ;D). Solved the filter problem in an other way, bought an Green Twister Air Filter (wich is in a housing) and connected the snorkel to that. On top of the pipe I made a cup to keep the water out. Will post some pic's when I get home.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #11 on: December 01, 2004, 08:38:59 PM »
Dat had je wel gewoon in het Nederlands kunnen posten hoor ;). Ik had jouw oplossing al op een andere - Belgische - site zitten bekijken  :D
( for the "foreign" readers: I got an answer from a fellow countryman  ;D
« Last Edit: December 01, 2004, 09:48:16 PM by nitromax »
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #12 on: December 01, 2004, 08:39:29 PM »
Whoops, double  ???
« Last Edit: December 01, 2004, 08:39:54 PM by nitromax »
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #13 on: December 01, 2004, 09:32:50 PM »
Do you run a Carb version or an injection. as carb version tend to freese on the highway in the winter
my home made, by a local guy:-)
sorry about the mud but its stainless steel
below is a safari
expensive
had to take it of to make way for the cage
« Last Edit: December 01, 2004, 09:35:32 PM by mbmarkyb »
Markyb (UK)
UK Vitara JLX SE
« Reply #14 on: December 01, 2004, 10:59:19 PM »
I never had any problems with a genuine oiled K&N, some of the copies were rubbish though even when oiled. I used to carry a screwdriver with me to take the filters off when it rained.
I like my safari Snorkel, its a good fit, doesn't block your vision and its very strong. You could probably drive over it without damaging it. There are two types though, they are different lengths where they come through the fender - you have to get the right one for your airbox. I guessed wrong had to make an adapter for mine.
have a look at:
http://www.rhinoman.fsnet.co.uk
under mods, snorkel
