Kick auto trans help
  • 1796 Views
Offline IKUZUS
  • 21
  • You're right, I don't understand!
« on: June 13, 2007, 06:30:10 PM »
'95 4 door Kick auto........actual mileage and maintenance unknown. It shifts perfect through the gears but it will "jerk" kind of hard from park to reverse or park to drive. Maybe a broken mount? Tranny bad?? Any help will be appreciated. Thanks.
You're right.........I don't understand.
Offline Zooki
  • 38
Re: Kick auto trans help
« Reply #1 on: June 13, 2007, 08:13:36 PM »
This may or may not help, but if you have a locker( i.e. Detroit EZ Locker, Lock-Rite) in the rear, it will do this. There is a little "slack" in the rear end once they are installed. Noticeable with an auto, no so much with a manual. I have a Lock-Rite in my '97 Sport, and it does exactly the same thing. The locker manual says this is normal.
Offline RODW
« Reply #2 on: June 14, 2007, 02:25:23 AM »
Check the adjustment on the throttle kickdown cable. Other than that, mine did the same thing and one day it lost all drive in third gear so it cost me heaps to rebuild the transmission!
RodW
Offline IKUZUS
  • 21
« Reply #3 on: June 14, 2007, 03:54:40 AM »
It doesn't have a locker..........pretty much bone stock.
That's what I was afraid of RodW.  :(
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #4 on: June 14, 2007, 07:25:36 AM »
check your ujoints for play, they will cause this too. get a friend to sit in truck and shift it while you look under to see whats moving. Be sure to block the wheels and set the park brake first though
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
